It is currently Sat Jun 13, 2026 10:03 am
PostPosted: Tue Mar 09, 2004 8:03 am
Anyone ever replaced the rubber seal in the front outport shaft in a 79 4x4 luv's transfer case? My son's trying to replace his and no matter how he puts the new seal in it leaks. No transmission shop knows what to do.
PostPosted: Tue Mar 09, 2004 6:57 pm
might try running some grease on the seal or the shaft before installing it. It might not be sealing well is all and a little grease as a prelube will help. Also put the open end twards the case. Hope that helps.
