It is currently Sat Jun 13, 2026 5:02 am
 Post subject: AWD LUV
PostPosted: Fri Feb 13, 2004 2:24 pm
another question.....hey if you dont ask you never learn!!! i want to look into making my luv into awd... i just want any suggestions on ways to start this project...thanks randy
PostPosted: Sat Feb 14, 2004 3:02 pm
Just go pick up a 4x4 LUV! :roll: :lol: That way you got AWD whenever you want, plus if you want 2WD you got that too! :D
But if your looking for a true AWD, then I'd say find a old AWD vehicle, and pull out the drivetrain and do a swap! A hell of a project....but it would be extremely cool 8)
PostPosted: Sat Feb 14, 2004 4:17 pm
gut a quadratrac transfer case out of a jeep, there's a lot of AWD ones out there, and hook it up
PostPosted: Sat Feb 14, 2004 4:37 pm
I think I posted a topic on this once, because I had the chance to pick up a drivetrain from a totaled out GMC Syclone. Man I wish I would have done it anyway, but the drivetrain was back home in Texas and another guy came up with the cash first. Well just my two pennies.
Later
Husker
PostPosted: Sat Feb 14, 2004 7:48 pm
would the 4x4 luv parts hold up with a v8 ?
PostPosted: Sat Feb 14, 2004 10:43 pm
most likely not. if i was ever to make a v8 powered 4x4, it would have a straight axle sitting under it anyhow
PostPosted: Sun Feb 15, 2004 1:51 am
gut a jeep for it. youll get dana44 axles and the quadra trac T-case. That shoulkd hold up to a v-8, they run 318s in the grand cherokees
PostPosted: Sun Feb 15, 2004 6:09 pm
What about an Astro van front end? Ive seen them with v8s. Ive beat the snot out of mine and all Ive done so far is break a torsion bar in half.
PostPosted: Mon Feb 16, 2004 4:30 pm
the thing is, why go through all the trouble of gutting some ifs setup off an astro when you could pick up a straight axle and some leaf springs?
PostPosted: Wed Feb 18, 2004 7:11 pm
what im trying to do is get the extra traction for coming off the line...would the jeep parts be geared too low? or would it matter? i am not too sure of the mechanics of the transfer case.......
PostPosted: Wed Feb 18, 2004 7:56 pm
unless it's something wierd, hi range should be 1:1, so it shouldn't make any difference. jeep axles are typically geared up in the 2.xx-3.xx range, but you could get them regeared if you need to.
fullsize jeep stuff(out of a j series truck, big wagoneer/cherokee etc) would probably be stout enough to hold up to some horsepower. remember, these came available with 318s, 360s and 401s from the factory
PostPosted: Fri Feb 20, 2004 10:31 am
thanks for the advice i'm gonna try to find one now... :twisted:
