It is currently Fri Apr 19, 2024 2:58 am
 Post subject: EGR system delete/bypass
PostPosted: Sat Jul 13, 2019 6:37 pm
Hey I'm looking to delete/bypass an EGR system on my 1979 luv. Anyone know how to do this?
PostPosted: Sun Aug 18, 2019 5:24 pm
I just cut the crossover tube between the exhaust and intake and brazed in an appropriately sized bolt to close off the tube end. I then cut off the injector rail and brazed shut and reinstalled each air injector. This saved me from having to find the right covers and or plugs. Someone mentioned the air injectors can be plugged with a spark plug. I dunno, never tried that. My "cut and braze" method worked just fine on my truck.
File comment: The crossover tube at the intake. Cut and brazed shut with a bolt and reinstalled.
File comment: The crossover tube at the exhaust. Cut and brazed shut with a bolt and reinstalled.
File comment: The air injectors are cut, crimped, brazed shut and reinstalled.
1977 LUV Barn-find. (And my favorite thing to drive!)
PostPosted: Sun Aug 18, 2019 5:32 pm
I am sorry. I accidently also included information on removing the air injector rail. That is only necessary if you are deleting your smog pump. I did my egr, smog and new carb all at the same time. I forgot they were separate systems.
PostPosted: Mon Aug 19, 2019 10:21 am
I have this smog delete plug kit for $20 shipped, payable via PayPal. PM me.
A 12mm installation tool for the EGR plugs is included & you may not need the O2 fitting plug.
Fits G180Z, G200Z, 4ZD1, 4ZE1 engines.
PostPosted: Thu Mar 05, 2020 8:44 pm
Hey there oldestisuzuist if you still have those smog delete plugs for sale I would love to buy them for my g180 motor on my 79 Luv. Let me know if you still have them for sale. Tried to PM you but it wouldn’t let me. Thanks!
PostPosted: Fri Mar 06, 2020 9:15 am
You should now be able to send PMs
PostPosted: Fri Mar 06, 2020 6:12 pm
Please don’t cut the EGR pipe if it comes off without too much issues. We in California are in dire need of them, I don’t need one but I buy them as they come up and when someone needs one to pass smog I sell them for what I paid for them.
PostPosted: Thu Jun 04, 2020 6:03 pm
I am in need of the air switching valve if you are deleting all your smog stuff. smog test coming this year.
76 LUV
PostPosted: Sun Jan 31, 2021 2:44 pm
Does anyone have those kits available? I’m new to the forum and can’t PM yet.
