It is currently Tue May 26, 2026 7:42 am
 Post subject: Windshield project
PostPosted: Wed Jun 07, 2017 6:22 am
I'm very lucky that I have only one small chip. I'm not good enough to tell if it's been repaired.
I'll take it to the experts. The real problem is the rubber seal. It really leaks and will have to be replaced when I paint the truck.
Any ideas on the new seal? I don't know if there's a universal seal. The odds one the original shape availability is slim?
I'll keep you posted.
 Post subject: Re: Windshield project
PostPosted: Thu Jun 08, 2017 8:17 am
The glass shop should be able to still order the rubber seal. Just cross your fingers it don't break when they remove it cause replacement windshields are nill unless you find a parts truck or want to pay big bucks.
PostPosted: Thu Jun 08, 2017 7:39 pm
I ordered a brand new windshiled gasket from Ebay, a seller from thailand. Fits perfet. Very easy to install with a 14ga wire
My luv project
https://youtu.be/wd5eCjrNL6U
PostPosted: Fri Jun 09, 2017 6:32 am
I'll check. I hope front and rear are the same.
PostPosted: Fri Jun 09, 2017 8:34 am
Nope...
PostPosted: Sun Jun 11, 2017 2:31 pm
You can order both rear and front glass gaskets. There is a listing in Ebay for both gaskets.
My luv project
Users browsing this forum: Google [Bot] and 30 guests
