It is currently Fri Jun 12, 2026 10:18 pm
PostPosted: Mon Aug 01, 2016 8:01 am
I have looked through some of the pages at the gauge panels fellow builders have done but I know I haven't seen them all. Could I get you guy's to post what you have done here so I can get some ideas. We are doing speedo, water, oil, volts, fuel and a tach which we will dash mount. We are using the phantom 2 gauges on this install. Thanks guys.
PostPosted: Mon Aug 01, 2016 2:24 pm
Dibs on your stock stuff , but here is mine . Plate aluminum with old school stuff plus A/F meter .
PostPosted: Sat Aug 06, 2016 6:57 am
So no one other than Hotrod has done this????? hard to believe that. Thanks Hotrod and if I get rid of the factory cluster you'll be first in line.
PostPosted: Sat Aug 06, 2016 7:31 am
I have done it but not sure if it would be much help as I went digital.
PostPosted: Sun Aug 07, 2016 3:16 pm
Thanks tilted. I'm just looking for material used and the lay outs, everything helps sir.
Users browsing this forum: Baidu [Spider] and 31 guests
