It is currently Wed Jun 10, 2026 2:41 am
PostPosted: Sun Oct 25, 2015 11:17 pm
Just registered member, always used this site for references and troubleshooting, awesome guys on here decided to join and share some experiences. Just put a 327 in a 78 luv I picked up a couple months ago and the whole project has been trial and error breaking new ground. Just want to share some pics and see if anyone has some questions on a similar project. The motors not built, stock besides carb and intake but scoots the luv how I imagined. Th350 tranny, stock 2wd rear end (for now) northern radiator, manifolds of late 70s nova, flowmaster super 10s and ACE motor and trans mounts. I still have a couple questions of my own like hooking up the speedo, and getting the stock oil light to stay off, or actually function properly. Does anyone know if you can make the stock temp gauge work accurately? I'm also not sure about a where and tire setup, I'm having a real hard time hooking up and not spinning. Again, and questions or comments I could love to hear thanks.
PostPosted: Mon Oct 26, 2015 12:12 pm
WELCOME WELL ITS ABOUT TIME YOU JOINED 8)
I always liked the 327 engine
PostPosted: Mon Oct 26, 2015 10:57 pm
[img][img][img][/img][/img][/img]Thanks I know! I've never had any experience with a sbc so since I didn't plan on building a motor at all the 327 seemed like a pretty cool stock motor to put in, especially for the price. Any suggestions on an affordable rear end with posi? I need more traction and would be nice to actually spin some descent cookies.
PostPosted: Mon Oct 26, 2015 11:15 pm
The cheapest option is one out of an s10. It is slightly wider, but the correct offset wheels will correct that...
PostPosted: Mon Oct 26, 2015 11:28 pm
That's the route I was thinking, but aren't the 4x4 rear ends wider then the 2wd? But the 4x4 has the posi, can you just swap the third into the 2wd housing?
PostPosted: Tue Oct 27, 2015 12:11 am
Yes, as long as it has the same spline axles (some 8.5's had larger axles than others). Most 2wd s10 blazers had a posi also...
PostPosted: Tue Oct 27, 2015 8:50 am
Welcome aboard! Good way to get the temp gauge working is to adapt the stock luv temp sender to fit a port on the Chevy, way I heard involved using a pipe plug the size of the Chevy sensor and drill/tap it so the luv sender screws in. I havent seen any chevy sensors that work with the stock gauge yet.
Definitely scoots along with the 327 doesn't it! Did you ever drive it with the 1.8 or was it bought to swap?
PostPosted: Tue Oct 27, 2015 9:11 am
These are the s10s that have the 8.5 along with the codes for the gear ratios and the g80 gov-lok diff
S10 Pickups
1995 s10 2wd 8.5 rear, (LB4,L35,M30,GU6)
1995-1997 s10 2wd 8.5 rear, (LN2,M30,GT5)
1996-1999 s10 2wd 8.5 rear, (L35,M50,GU4,G80)
2000-2002 s10 2wd 8.5 rear, (M50,GU4,G80)
2003 s10 2wd 8.5 rear, (LU3,M50,GU4,G80)
S10 Blazers
1995-1997 s10 blazer 2wd 8.5 rear, (L35,M50,GU6,G80)
1998-1999 s10 blazer 2wd 8.5 rear, (L35,M50,GU6,G80)
2000-2001 s10 blazer 2wd 8.5 rear, (L35,M50,GU6,G80)
2001-2004 s10 blazer 2wd 8.5 rear, (M50,GU6,G80)
2003-2005 s10 blazer 2wd 8.5 rear, (M50,GU6)
PostPosted: Tue Oct 27, 2015 9:48 am
Oh ok good idea on the temp sensor I'll look into some fittings. I have an aftermarket one hooked up for now, never gets above 170-180 so that's a relief without an electric fan. Thank you for the s10 codes t g at helps a lot! And this one I bought to swap so never drove it, but I have an 80 4x4 with the 1.8 just webber and header and the 327 is a world of difference! I would post pics but it says their too big of file? Idk
PostPosted: Tue Oct 27, 2015 10:06 am
Try downsizing them or upload to photobucket and resize before posting
I had the 1.8 for a couple years.. dropped in the 4.3 and haven't regretted if except at the gas station. Much more fun to drive and the torque is great hauling a load
Users browsing this forum: Baidu [Spider], Google [Bot] and 30 guests
