It is currently Thu Jul 02, 2026 2:53 pm
 Post subject: Well the snows came...
PostPosted: Fri Nov 21, 2003 3:19 am
Theres a good amount of snow on the ground tonight, atleast 6-8" where i live. So naturally i whent out a drove around a little bit. All i have to say is 4wheel drive is not realy that much help in snow. I was out on the roads driving in both 2wd and 4wd and all i noticed between the two was that when down shifting the truck stayed straighter in 4wd...
So that done i hit the open wall mart parking lot and did some donuts and hard braking to see how the luv handled and what to expect(this beeing my first real winter of driving) and i still didnt notice too much diference between 2wd and 4wd. All that it did was whith 4wd kept the truck straighter under simple things, but i could still get it wild just as easy. No wonder so many people have trouble in the winter if they thing 4x4 AWSOME... :?
PostPosted: Fri Nov 21, 2003 4:08 am
what type of tyres do you have on your truck :?:
PostPosted: Fri Nov 21, 2003 4:23 am
right now i have my all terain tires on it. They are Eldorado ZR4 radials. They do realy well whith grip and such, i can actually brake perty hard before they slide.
PostPosted: Fri Nov 21, 2003 5:08 am
What size are they
PostPosted: Fri Nov 21, 2003 7:02 am
is there something wrong with your 4 wheel drive ? does it sound okay ?
my luv rules in the snow. i can pretty much do everything i want and it still sticks to the ground. i even have the puney stock size tires :?
PostPosted: Fri Nov 21, 2003 12:43 pm
Japanese Redneck
bummer, it was like 75 degrees here the other day. It is getting cooler though... it may get into the 50's at night real soon.
PostPosted: Fri Nov 21, 2003 4:06 pm
I used to have a v.w. bug....and it would run circles around any 4x4 in the snow..
PostPosted: Fri Nov 21, 2003 4:27 pm
they are 28x8.50R15. The 4x4 works perfectly. All i was saying is that 4x4 isnt the be all end all of snow traction. I need 4x4 to get out of my driveway so it does help. But on the road its not that big a deal is what i was saying. 4x4 or no, if you dumb youll still loose it.
PostPosted: Fri Nov 21, 2003 5:00 pm
speaking of snow, i had a branch the size of a luv fall onto my luv and my s-10, i was pissed, it destroyed the windshield in the s-10, almost hit my sunroof on the luv, bounced off my back window on the luv, and put a little brach through my bed between the floor of the bed and the wall. it splt my bed apart all the way to the top of my wheel well, OH GOD I WAS PISSED!!!!! But i pounded the side of the bed back in, cant even tell anything happened, and ill get my bed welded sometime soon. and as far as my s-10 is concered, i was just gonna get rid of that anyways.
PostPosted: Fri Nov 21, 2003 6:32 pm
man that sucks. Im glad i park where no trees can fall on my rigs 8O
