It is currently Fri Jun 12, 2026 8:34 pm
 Post subject: 76 LUV brake replacement
PostPosted: Sat May 03, 2014 9:57 am
I have 1 76 with a 350 small block....want to give my brakes better stopping power. I have 6 lug disc brakes on the front, but they're autozone. Tired of replacing the pads every 6 months. Looking to replace the rotors, caliper and pads. Any suggestions?
Perception is 9/10 of the flaw
PostPosted: Fri May 23, 2014 11:07 pm
i have a set of vented, drilled and slotted 85 isuzu trooper rotors i got off ebay im using with with stock calipers and they work pretty good. idk about longevity i have only had them a couple weeks
PostPosted: Fri May 23, 2014 11:19 pm
You can do the vented discs. I can't understand why you are going through pads so often. I have stock solid rotors, my hubs are custom made and 5 lug and have no issue at all on stopping power. My rear drums are 11X3 I think. The only bolt on front brake system out there that is better then stock is aerospace brake system. Let me find the link. This will also convert to the 5 lug system.
EDIT: Found it. It says 79 and up LUV but they work for all of the LUVs that have front rotors. Spendy but those that have them like them
http://shop.aerospacecomponents.com/4pi ... vrdsp.aspx
A bit cheaper here.
http://www.ebay.com/itm/Aerospace-Heavy ... 4897.l5658
