It is currently Sat Apr 11, 2026 5:37 pm
PostPosted: Sun Sep 08, 2013 7:10 am
I am wanting a hitch to haul a motorcycle trailer with our 2 rebels on it. I can probably get one custom fabricated, but would it be ok to tow a trailer with 2 motorcycles on it a good distance? We plan on taking the bikes in the Luv 4 hours away for our anniversary.
PostPosted: Sun Sep 08, 2013 8:28 am
My guess is that you will have to buy one of those adjustable hitches. It shouldn't be too hard to make it fit the Luv. Make sure and post a picture or two if you find a solution.
Here's an example:
http://www.etrailer.com/Specialty-Trailer-Hitches/Curt/13703.html?feed=npn&gclid=CMOKypGBvLkCFa1FMgodlEAASg
PostPosted: Sun Sep 08, 2013 8:34 am
I used to tow a bass boat with a ball on the stock bumper. The step bumpers have a higher tow rating than the standard bumpers, but the only difference I see is the step bumpers use three frame mount bolts per side instead of the standard two. I just added a third grade 8 bolt.
Stopping is more of a problem than towing, adjust your driving habits accordingly.
You will have to add a converter adapter to connect your separate signal/brake lights to the combo trailer lights, if you can't find one specifically for LUV/Isuzu one from a Toyota pickup will work, you just have to splice the correct wires together, LUVs were before the now-common plug-&-go trailering connections.
Users browsing this forum: No registered users and 62 guests
