I ordered the last in stock engine mounts that jegs had today! whoohoo!
I am going to use these mounts to dial in where I want the engine then later on down the road I will install the front engine plate.
depending on the design of the mounts I might fabricate some for anyone that wants some. I am the draftsman at a fabrication shop and if some of you want mounts I can make them at half the cost of the hooker mounts.
I will let you know when I get them if I decide to make some.
I am also placing an order for a bunch of stuff this week including an 8 point roll cage, fuel cell and all the ignition needed for the buildup.
I will be putting pictures on the webpage as I install all of this.....so stay tuned!
