It is currently Fri Jul 03, 2026 4:28 pm
PostPosted: Mon Oct 27, 2003 4:30 pm
[img]http://images.cardomain.com/member_images/9/web/321000-321999/321285_89_full.jpg[/img
PostPosted: Mon Oct 27, 2003 7:23 pm
so it was you over on ck5.com. I didnt think there were many other people that wheeled chevtes on luv frames :lol:
PostPosted: Tue Oct 28, 2003 6:01 am
cool pics man!
flex is guud! :D
03Cobra
PostPosted: Wed Oct 29, 2003 8:34 am
Cool pics. 8) 8) Nice to see their are stillpeople out their who use toys for what they build them for and not just for show.
PostPosted: Wed Oct 29, 2003 2:32 pm
I dotn see the point fo spending all this money on a truck that doesnt get used.... So far, this ole girl ahs been on her side, had a leaf spring busted, had 2 engines blown in her.. and twisted a drive shaft off, and she is still out on the trails. Future plans are. exo rollcage, after I rebuild the engine...again... foudn the problem... oil pump dioesn tpump enough oil to keep the engine goin with the pull of the 4x4... one 55 dollar hi volume pump will fix the problem
PostPosted: Wed Oct 29, 2003 10:22 pm
man you sound like a friend of mine that has a talent for breaking ANYTHING on a truck :lol:
PostPosted: Thu Oct 30, 2003 5:51 pm
The leaft srpring busted when I rna hea don into a rock, and the drive shaft twisted ebcuase of a lousy weld on my part. The engine were nto m fualt. 3.8 only has 1.5 pound of oil pressure at 1500 rpm, and 37 ar 3500... I was locke din 4lo over an hour at idle (1,000) so they starved for oil and spun rod bearings. Found out that for 55 dollars I can get a hi volume pump, not I need to fidn out where I can get these at. Anyone know? I have 2 more 3.8's and I dotn want to put anothe rin until I get the oil pump problem solved. Then its exo cage and paint....
PostPosted: Thu Oct 30, 2003 5:52 pm
