It is currently Fri Jun 26, 2026 2:58 am
PostPosted: Tue Nov 27, 2012 5:26 pm
ok im doig this on a budget i have a 283 and im tired of messing with the 1.8 i grew up working on v8 chevys but not any good when it comes to izuzu so i was just wondering if anybody had completed a v8 into a 4x4 luv swap could give some advise i can order the pan to clear frond diff but not sure on transmition i would like to run a five spd
if it aint a luv it aint shit
PostPosted: Thu Dec 13, 2012 12:21 am
Your problem is ataching the transfer case to the back of either an auto or manual trans. One way is use a divorced transfer case, make a cradle for it and a short shaft to connect to trans. The other is get a 4WD trans and transfer case and instll that. Make sure you get a transfer case that drops on the correct side.
PostPosted: Thu Dec 13, 2012 8:12 am
you will need a passenger side drop transfer case, i know there were a couple chevys with them i think it was a 203 or 205 case, will need both driveshafts replaced or modified, not sure of length difference between them. you may be able to find a 4x4 t5 with the rhd case that will work for you.
as for the oil pan vs crossmember you will probably end up modifying both, if you have the 283 already is it a front or rear sump? i would try lowering it in as close as you can get to where it will be sitting and seee how much room you need. im not sure that there are any pics of what a completed install looks like and i havent seen it done yet.
if you are up for making a custom crossmember you can avoid that whole problem altogether and have one that fits right without messing with oil volume and such. you will also need to modify the trans crossmember and possibly add some support for the transfer case
Users browsing this forum: Baidu [Spider] and 37 guests
