It is currently Mon Jun 29, 2026 7:59 pm
 Post subject: pacesetter owners ...
PostPosted: Sun Oct 03, 2010 12:34 am
do you have pictures of where the header sits compared to the frame?
OR ...
do you have a measurement of how far the header hangs past the frame rail
PostPosted: Tue Oct 26, 2010 10:52 pm
Don't have a pic, but the header is pretty much in line with the frame. And with the header connector and flange comes to about 8 inches from the trans crossmember. Had to have the muffler shop make a piece that has about an 6" drop to clear the crossmember and connect with the stock exhaust. If you have a custom exhaust pipe bent then you can run it over the crossmember. I've had to reweld mine a few time after scraping it on a speed bump..
Hold on to your lug nuts, it's time for an Overhaul!!!!!!!!!
