It is currently Mon Jun 29, 2026 4:16 am
PostPosted: Sun Sep 19, 2010 4:42 am
Primary Vacuum Break on the carberator,pulley arm wasn't attached to any controller. This is off a dch340. Would this have been the reason why all of a sudden I couldn't now start my 80 Luv?
BETTER TO BE FREE WITH DREAMS OF CAPTURE, THAN CAPTURED WITH DREAMS OF FREEDOM.
PostPosted: Wed Sep 22, 2010 8:36 pm
Any pics? Don't know what your asking, or what your referring to?
PostPosted: Wed Sep 22, 2010 8:37 pm
12.52 DC volts with all switches off & all battery cables clamped to posts(But the heater has no off switch). Then the following with the neg. cable off the batt. post, with a volt meter touching the batt. post(-) and the other lead on the clamp of the ground cable, making sure not to touch anything with the neg. cable clamp.
(Ignition Switch) (Voltage-DC)
Off 12.25
Acc 12.40
On 12.47
Start 12.47
Dead short some where as can't get any spark.
PostPosted: Thu Sep 23, 2010 5:51 pm
Done. So now at 5.5 vdc without any fuses in. Then put 1 in at a time & the voltage never changed until I put the horn fuse in, then it went to 10.5 vdc, then when the tail fuse was put in, it went to 11.5 vdc. Now where?
