It is currently Sun Jun 28, 2026 1:01 pm
 Post subject: Name that Wheel!
PostPosted: Sun Aug 15, 2010 1:05 pm
http://charlotte.craigslist.org/pts/1848535125.html
Just picked up this set of wheels for my Luv for $40
I think they are called saw blades or directionals
If you know the real name of this style of wheel, let me know. Thanks.
1990 Chevy Suburban
 Post subject: Re: Name that Wheel!
PostPosted: Sun Aug 15, 2010 4:06 pm
I usually heard them called saw blades, but directional was used also.
My brother had them on his LUV back in the late 80's
PostPosted: Mon Aug 16, 2010 3:10 am
Australian LUV Guru
Take a good look at them wheels and guess whats wrong :esurprised
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Mon Aug 16, 2010 4:29 am
They look good to me. 6 lug, 2 go one way and 2 go the other, so they look right on the truck, but sucks at rotation time. ( I had directionals on my old Suburban.)
PostPosted: Mon Aug 16, 2010 9:31 am
:smt102
PostPosted: Mon Aug 16, 2010 9:34 am
The inset?
PostPosted: Mon Aug 16, 2010 2:08 pm
TILTED wrote:
:smt102
:smt102 x2 The only thing I can figure is on one pair the blades spins the opposite from the other. As long as I pair up the correct set on each side of the truck, I don't see what the big deal is. Or I could have them spinning in opposite directions on the same side of truck and really mess with peoples heads!
1990 Chevy Suburban
PostPosted: Mon Aug 16, 2010 2:49 pm
Australian LUV Guru
maduro-man wrote:
TILTED wrote:
:smt102
Correct. I see this a lot, wheel manufacturers to cheap to make two moulds.
PostPosted: Mon Aug 16, 2010 2:56 pm
Ok, I am still lost. There are 2 lefts and 2 rights in the picture, hence the term directional.
PostPosted: Mon Aug 23, 2010 10:56 am
I see nothing wrong either. Tire rotation with radials is front to back and not criss-cross, so rim orientation stays the same. Much better than having rims that appear to be backwards on one side of your truck.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Sun Aug 29, 2010 6:43 pm
looks like progressive's or could be ultra's....used to have a set of them on my old Dodge D-50 back in the day 8)
Stick Shift Racing
