It is currently Fri Jun 12, 2026 11:49 pm
 Post subject: wheels from the '70s
PostPosted: Thu May 06, 2010 7:53 pm
alright the general theme for my truck is to keep it stock as possible. granted im doing a 350 and air-ride, i want everything else as original as possible.
i have these wheels and hubcaps. 14" stock wheels.
i am wanting to know if these hubcaps can fit a modern 15" wheel? i am converting the truck to 5 lug with s10 stuff. i want to make it look old school.
i just got distracted. dont know if any of this makes sense.
can i get these hubcaps pictured to fit a larger diameter steel wheel? or does anyone know of any hubcaps that closely resemble the stock luv caps?
 Post subject: Re: wheels from the '70s
PostPosted: Sat May 08, 2010 6:16 am
Man is that your garage with a lift, if so awesome,
PostPosted: Sat May 08, 2010 8:34 am
i could only dream sir. its my friends body shop where i keep the truck. so in a manner of speaking, its mine. or at least i have access to it
PostPosted: Sat May 08, 2010 9:18 am
I was wondering the same thing. Jealousy meter was going to go way up. lol, good luck with your Luv build.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sat May 08, 2010 1:18 pm
Do you know were the Augustus Winery is. June 5th I am supposed play a gig there from 3-7 outside. Chuck Berry's daughter is supposed to be there also.
PostPosted: Tue Jun 08, 2010 12:25 am
I saw an older full size Chevy the other day that had basically the same hub caps, but the wheels where at least 15s. Maybe track down a set of those if these don't work?
1975 Project LUV
It's ALIVE!
PostPosted: Tue Jun 08, 2010 5:44 pm
actually forgot to post this up. i picked up a bunch of s10 stuff for when i swap everything out. got some 14" rally wheels from an s10 and my caps fit. so pretty much they will fit any 14" steel wheel from what ive tested them on.
ill get pictures next time i think about it
