It is currently Mon Jun 08, 2026 11:08 pm
 Post subject: i need ur view on this
PostPosted: Fri Mar 19, 2010 8:24 pm
im looking at a 1991 ford F350 (Not Dually) with the 7.4 diesel motor with the banks turbo sounds good dont smoke . its 4X4 has 240000 miles on it clean truck its the light tan color. it has m/t rims is it worth $3,000 ???
75-luv mikado-V8 350 soon
PostPosted: Fri Mar 19, 2010 8:59 pm
That doesn't sound too bad to me. That was the last year of that body style and the 7.3 is a great engine, especially being upgraded w/the turbo. If it is a supercab it would be more valuable than the standard cab, in my opinion. If there is no rust it's probably worth it. Are they asking $3K or is that what you are thinking of offering?
PostPosted: Fri Mar 19, 2010 10:47 pm
its the 4 door cab and that what the guy wants no rust cail truck
PostPosted: Sat Mar 20, 2010 12:37 pm
Auto Tranny or manual ? How are the tires? Tires can cost you more than $500, but I think a single wheel truck is better than a dully in a WHOLE lot of cases. Unless you are carrying more than 15,000 lbs you do not need a dully. Sounds like a ok Price. I like a Cummins engine better. But you should have seen a non turbo 7.3 I think the 7.3 has some better qualities than the 6.0 Drive it.. It should have ok power. If you feel better have a shop check it out. That should be a $100 or so. They can run a compression and leak down test on it. Remember it costs more than a gas engine to repair. A lot of things a lot more.
PostPosted: Sat Mar 20, 2010 1:09 pm
AUTO TRANS TIRES ARE GOOD
PostPosted: Sun Mar 21, 2010 7:12 am
Sounds like a good deal. I just sold my 88 Chevy 1 ton dually with a BBC with 143,000 miles for $2500. It was in good shape.
PostPosted: Mon Mar 22, 2010 3:00 pm
im looking for a radiator 1976 automatic
