It is currently Sat Jun 13, 2026 9:17 am
 Post subject: drag racing
PostPosted: Thu May 22, 2003 2:31 pm
ok what kind of times are yall running with nitrous lets here it :) :lol: or on motor it is hot as ----------in south la but did run 11.24 on motor 10.48 on 100shot
 Post subject: hopefully
PostPosted: Sat May 24, 2003 12:07 pm
when I get it together it should go some 10.50s/10.60s with the pulleys moved around I should get it in the nines easy..............
PostPosted: Sat May 24, 2003 12:33 pm
thats pretty good mit come to bay town on june 28for races how about you 77ssluv hows that luv
PostPosted: Sat May 24, 2003 3:10 pm
i run 11.95 on the motor i haven`t bolted the bottle on it yet. i have to get a cage first then i can put it on along with the alky carb, combine that with some deeper gears i should be in the 10s to low 11s :twisted:
PostPosted: Sat May 24, 2003 3:32 pm
hey polished steel i saw your bidding on that clean luv on ebay. hopefully you get it man :D
 Post subject: hey polishedsteel
PostPosted: Sun May 25, 2003 7:37 am
Let me know if you go to the clash of the titans race.I'm thinking of going matbe we'll get together and have a couple of beers......... :drinking:
PostPosted: Sun May 25, 2003 12:04 pm
good luck to all at drags changing to solid cam 570 lift hope it goes in 10's on motor GOTTA LUV IT!!!!!!!!!!!!!!!!!!!! PAINTED LUV METALLIC BLUE WILL BE SENDING PICK TO ADD TO MY PICS TAKE CARE FROM POLISHEDSTEEL OFFSHORE GULF OF MEXICO
PostPosted: Sat May 31, 2003 5:09 pm
well i bought slicks and put the alky carb on my truck.dropped my times from 11.95 to 11.63 on the first pass. i got warned by the officals again to get a cage so i had to back out the rest of the night. so i didn`t get to adjust on it much.i ordered a cage from s&w i should beable to make full passes in a couple of weeks. :twisted:
PostPosted: Sun Jun 01, 2003 8:43 am
Hey Racelife, 3 tenths is pretty good, I'm sure it's got more in it. Let me know when you get that cage kit from S&W. I have one in my other drag truck and I was pretty happy with it. Are you getting an 8 or 10 pt?
PostPosted: Sun Jun 01, 2003 5:31 pm
i`m going with a 8 point, its good until 10.0 as long as your fire wall isn`t modified. besides i didn`t have the extra cash either since i have to have updated belts too. my 5 point is out of date. it was still like 101 deg out when i made my first pass so between some cooler temps and doing some jetting i`ll get it down more yet.i ordered the cage friday mourning i don`t know how long it will take to get it. there in pennsalvania i`m in phoenix so i figure about 6days since it has to be shipped by truck. i`m gonna pick up some lexan today from home depot for the back window.by the way s&w is having a sale on there cages if anyone else is looking 40.00 off don`t know how long it lasts though. later
 Post subject: roll c age
PostPosted: Sun Jun 01, 2003 9:13 pm
man when i installed my roll cage tired every way not to cut above rear window but had to to weld the cage better looking et what kind of 60 ft did you have and mph hour Take care from South La 8)
PostPosted: Sun Jun 01, 2003 9:36 pm
40 bucks off, huh? That's a pretty good deal. Maybe I'll work on momma a little and see if she'll let me go ahead and order one, hehe. :wink:
PostPosted: Sun Jun 01, 2003 10:16 pm
1.62 60ft and 115 mph still running a 2.80 gear ratio out back with 29 inch tall slicks. i wish i could afford some better gears so i could actually use 3rd gear. it would probably drop my 60 ft times even further and et. later :lol:
 Post subject: not bad
PostPosted: Mon Jun 02, 2003 9:09 am
Japanese Redneck
1.62 short times are good!!! especially with that "freeway" gear. was about a 11.80ish pass no?
PostPosted: Wed Jun 11, 2003 10:52 pm
WOW! Low 11', low 10's, low 9's WOW! 8O 8O
Im running 22.3 in the quarter :lol: bone stock 1.8L though :lol:
Just wait for the 400 and the turbo 350.......hehe then i should see them single digits :twisted:
 Post subject: N DA 9'S
PostPosted: Sun Jul 13, 2003 11:37 pm
IM IN THE 9'S ON 150 SHOT WITH A 1.62 60FT SMOKING THE 29.0 9.0 15'S THATS 110MPH AT THE 8TH 138MPH IN THE QT AT 95 DEGREES GETTING READY TO TUB THE SILVERBULLET 33/13/15'S LOOKIN FOR THE 8'S
Users browsing this forum: Bing [Bot] and 21 guests
