It is currently Fri Jun 12, 2026 8:49 pm
 Post subject: FAT TIRES WANTED
PostPosted: Thu Aug 15, 2002 9:35 am
Hey i noticed some of you guys have had your Luvs tubbed. I want to tub my 74, my question is how much will it cost and, new suspension and all, labor included since i dont know how to do it, ...and what size wheel and tire will i be able to run..i want to keep the gear kinda tame so i can cruise in it...any input welcome-Gus
PostPosted: Thu Aug 15, 2002 7:05 pm
:drinking: Hey Gus
You can tub a truck fairly cheap,if you know a good fab guy.I am currently tubbing my 75 luv.It will have 15x12 weld rodlites,with 31x16.5x15 et streets.The rear is a 9" .I had a friend narrow the housing for me.Sent the axles to Mosier engeneering.For $189.00 they cut my axles ,resplined them "31" and restuded them to a smaller bolt patteren.as far as cost it all depends on what you want.My rear suspension is going to be a homemade set of lift bars .......cheap cheap cheap.Hope this helps.
 Post subject: Re: FAT TIRES WANTED
PostPosted: Thu Aug 15, 2002 7:41 pm
you can tub a luv pretty cheep, I have about 1,000 in my back half(mandrell bent frame rails narrowed 9 inch ford ladderbars axles tubbs track locator) with out wheels and tires. oh ya coil overs also. :D :D :D
PostPosted: Thu Aug 15, 2002 11:05 pm
Hi Gus
how much it costs all depends on how fast you want it go .you can find a
good shop in your state and see how much they charge i'm howard king my truck is in the main pic gallery i built the 4-link my self widend
the rear fenders myself and had axles cut and resplined 31's i run a
28 12.50 15 M T street E T
PostPosted: Fri Aug 16, 2002 5:22 pm
:twisted: does anyone know if mosier engineering has a web site?
 Post subject: ?
PostPosted: Fri Aug 16, 2002 7:28 pm
I believe your looking for http://WWW.moserengineering.com. They do the axles and redrilling of the discs. Bryan
PostPosted: Fri Aug 16, 2002 8:04 pm
cool thanks for the info. terry
