It is currently Wed Jul 01, 2026 3:29 pm
 Post subject: 78 Recall ???
PostPosted: Tue Jun 10, 2003 2:25 pm
Automotive Recalls and Technical Service Bulletins for 1978 Chevy Truck Luv Pickup L4-110 1800cc.
Provided by ALLDATA
Emissions Recalls
TSB Number Issue Date TSB Title 78T72 FEB 79 Recall - Rough Idle/Black Smoke/Fuel Tank Vapors
General Recalls
TSB Number Issue Date TSB Title 410103 SEP 94 Campaign - Product Bulletin Numbering System
Service Bulletins
TSB Number Issue Date TSB Title 00-07-30-011 JUN 00 ACDelco(R) Remanufactured Transmissions - Program Update
00-06-03-006 JUN 00 Batteries - Settlement of Lawsuit (CA Proposition # 65)
00-03-10-002 MAR 00 Chrome Wheels - Chemical Staining
99-09-40-008 JAN 00 Child Restraint - Auxiliary Seat Belt
99-09-40-006 JAN 00 Lap/Shoulder Belts - Dealer Installed Rear Kits
99-06-02-017 OCT 99 Cooling - Radiator Repair/Replacement Guidelines
000000A JUL 99 GM Service Bulletin - Disclaimer
80-05-03 AUG 98 Warranty - Parts Warranty Special Claims B and C
87-61-24 APR 98 Engine - Surface Conditioning Discs Precautions
83-01-14 MAR 98 VIN Plate - Replacement Policy and Procedure
72-05-09 FEB 98 Warranty - GM Dealer Empowerment Program
82-05-01 FEB 98 Warranty - New Vehicle/Replacement Battery
73-50-37 JAN 98 Brakes - Rotor & Hub Flange Cleaning Tool Revision
72-05-12 JAN 98 Suspension - Shock Absorber/Strut Replacement Guidlines
72-05-14 JAN 98 Warranty - Enhanced Sublet Repair Policy
72-05-13 JAN 98 Warranty - Repair/Replace Policies & Procedures
73-01-10 DEC 97 Policy - Technical Assistance Call Preparation
72-05-11 DEC 97 Warranty - Rail Dust Removal & Chemical Spotting Labor
73-62-13A SEP 97 A/C - Servicing of Aluminum Heater Cores/Radiators
73-10-54 MAY 97 Windshield - Two-Part Urethane Adhesive For Installation
620504 APR 97 Warranty - Required Claim Submission Procedures
631215 NOV 96 A/C Compressor Seal Washer - Reference Chart
610111 NOV 96 Key Code - Information
400501A SEP 96 Warranty - Corporate Parts Return Program Instructions
636532 MAY 96 Enhanced Emission Inspection Maintenance - Equipment
536507 DEC 95 Enhanced Emission I/M - Program Update
588302A JUL 95 Vehicle - AC Delco Locator Service, Electronics Exchange
570102 JUN 95 Fuel - Reformulated/Oxygenated Gasolines
531205 MAY 95 Contaminated R12 Refrigerant - Testing & Handling
436201B APR 95 Coolant - Information on Propylene Glycol Usage
570201 MAR 95 A/T - Dexron® III Fluid Introduction
431218A MAR 95 Tools - A/C Leak Detector Maintenance Kit Availability
516502 FEB 95 I/M Emissions Diagnostic Manual -Program
420515A FEB 95 Warranty - Diagnostic Claim Processing Revisions
436510 JAN 95 I/M 240 Program - Equipment Purchase
436507 DEC 94 Enhanced IM240 Program - Implementation Plan
431048 NOV 94 Glass - Adhesive Caulking Kit Revisions
436506 OCT 94 I/M 240 Repairs - Obtaining Technical Assistance
446501 OCT 94 PROM/MEMCAL - Identification Marks
431223 SEP 94 A/C Refrigerant - Contamination
330105A SEP 94 GM Service Bulletin Numbering Explained
464101 SEP 94 Slip Yoke/U-Joint - Replacement and Servicing
436505 APR 94 Emission - Enhanced Inspection Maintenance Programs
033206 MAR 94 P/S - Reduced Assist When Cold
435001 FEB 94 Anti-Lock Brake - Aftermarket Products Usage Precaution
310504 FEB 94 Warranty - Recycled Engine Coolant Policy
331226 JAN 94 A/C - Retrofitting R-12 Vehicles to R-134A
367102R JUL 93 A/T - Cooler Replacement/Flushing
349212R JUL 93 Audio - Radio Frequency Interference (RFI) Diagnosis/ID
393504 JUL 93 Wheels - Sealing Leaking Cast Aluminum
316501R JUN 93 Tools - Introduction Of The Fuel Injector Tester
931638A MAY 93 Isolation Diodes - Replacement Information
9313310 MAR 93 Door Locks - Binding or Sticking or Key Hard to Insert
93966C FEB 93 Fuel System - Factors That Affect Economy/Mileage
9358A10 FEB 93 Paint, Base/Clear Coat - Acid Rain and Rail Dust Damage
93316C OCT 92 Fuels - Effect of Volatility on Driveability
922501A AUG 92 A/C - Use of Alternate Refrigerants In CFC 12
921599E APR 92 Engine - Block Heater Leaks
ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge
92267A OCT 91 A/T - New Trans Fluid, Dexron® IIE
912850A APR 91 Instrument Panel - Upper Surface Cleaning
911508C JAN 91 Instrument Cluster - Exchange Locator Program
911335 DEC 90 Brakes - Change In Brake Feel After Rotor Refinishing
911268E NOV 90 Wiper Blades - Chattering on Windshield
ATRATB028 OCT 90 A/T - Engine Vacuum Testing
91108A APR 90 Aftermarket Accessories - Installation Guidelines
91090A APR 90 Coolant - Used Anti-Freeze Policy
ATRATB9002006 FEB 90 A/T - Choosing the Right ATF
ATRATB8930 OCT 89 A/T - Math Part II
892531B SEP 89 A/C - CFC Reduction & Refrigerant Recovery Recycling
ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs
ATRATB8923 AUG 89 A/T - Math Formulas Part I
90496B AUG 89 Cooling System - Reconstituted Anti-Freeze Information
ATRATB8918 JUN 89 A/T - THM 200/200C No Passing Gear Above 35 MPH
883405 SEP 88 Brakes - Noise Repair Policy
883450A SEP 88 Seat - Rear Lap/Shoulder Belt Kits
ATRATB8834 JUL 88 A/T - Sprag Rotation
882456B JUN 88 Cooling System - Leaks
ATRATB8754 SEP 87 A/T - Front Bushing Wear
ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
ATRATB8741 JUL 87 A/T - THM 200/200C No Reverse
87129 MAY 87 Engine - Oil Change Requirements For Fuel Fouled Oil
ATRATB872 JAN 87 A/T - 200/200C No Passing Gear/Check Ball Mislocated
ATRATB8658 NOV 86 A/T - Slipping Or No Third Gear After Overhaul
ATRATB8620 MAY 86 A/T - 200/200C Soft Shift 1-2/Flare 3-2
8651 FEB 86 A/T - Understanding Identification Information
85546VI MAR 85 Maintenance - Updated Minimum Acceptable Oil Levels
ATRATB8538 JAN 85 A/T - 200C Coastdown Clunk Condition
ATRASIL859 JAN 85 A/T - 200C Identification
ATRASIL8523 JAN 85 A/T - 200C/2004R Updated Servo Cover Retaining Ring
ATRATB8543 JAN 85 A/T - Recurrent Sticking Valves/In Line Filters
ATRASIL857 JAN 85 A/T - THM 200 Pumps And Valve Bodies Interchangeability
ATRATB8547 JAN 85 A/T - THM 200C In Reverse Range Engine Stops Running
ATRATB8546 JAN 85 A/T - THM 200C Servicing Converter Clutch Apply Screen
78T22 FEB 78 EGR Thermal Vac. Valve - Broken Ports
ALLDATA has obtained this information from the original equipment manufacturers and others and ALLDATA believes it to be reliable.
PostPosted: Tue Jun 10, 2003 7:11 pm
Thats a hell of a list. And thats why I love hearing people say they dont build cars like they used to. I say thank god they dont. I love old cars, but talking to older generations of enthusiasts and hearing of some problems they had with old cars when they were new, new cars arent so bad.
