It is currently Sat Jun 13, 2026 4:10 am
 Post subject: bondo
PostPosted: Sun May 25, 2008 3:01 pm
can you use bondo on fiberglass , or what should be used ive got about a 1 inch crack in one of my fenders on the bed any help would be great
junkyard racing - we win with your old parts
 Post subject: Re: bondo
PostPosted: Sun May 25, 2008 3:17 pm
Bondo makes a fiberglass filler also,I've used it plenty.
PostPosted: Sun May 25, 2008 6:00 pm
it will work ok but eventually come off ... if you want to use just bondo get the duraglass it has small stands of fiberglass in it... the best way to fix it is to use both fiberglass and bondo http://www.youtube.com/watch?v=nBxnaY0mFMk
PostPosted: Mon May 26, 2008 3:38 pm
Very good video. You might want to reinforce the backside on a second or third layer of fiberglass and resin going wider on each layer to help prevent it from splitting.
Here is a link to a search on the hotrodders.com fourm
http://www.hotrodders.com/forum/search.php?searchid=1797799
It should help... I hate posting from other fourm's but they have a lot of knowledge there. Not on Luv Trucks but most other things like this.
PostPosted: Mon May 26, 2008 6:04 pm
i have been there a few times, great site for info
PostPosted: Mon May 26, 2008 9:31 pm
thanks alot :D :D
PostPosted: Mon May 26, 2008 10:05 pm
drill the end of the crack out too
