It is currently Wed Jun 03, 2026 2:08 pm
 Post subject: toyota rear end
PostPosted: Wed Apr 16, 2008 10:23 pm
is there any difference in a luv rear end and a toyota rear end ,
junkyard racing - we win with your old parts
 Post subject: Re: toyota rear end
PostPosted: Sat Apr 26, 2008 12:43 pm
i have wondered about this,i have several toy rear ends i have saved and from i see on them the solid axle toy trucks the rear ends are narrow the independent front suspension toy's the rear ends are 3 inches wider.also the spring perches are spaced farther apart and and on the on the top instead of the bottom of the rear end.so this would mean relocating spring perches.this would give a 6 lug pattern to match the stock luv front.they also resemble a 9 inch to me in many ways.damn neer every one of them are 4.10 gear ratio till like 93 and newer v-6 trucks had 4.56 gears.
When buying a used car, punch the buttons on the radio. If all the stations are rock and roll, there's a good chance the transmission is shot!!!
PostPosted: Sun May 04, 2008 4:14 pm
If your truck is going to be lowered the Toyota rar is too wide. At least the '90's rears are.
Users browsing this forum: Google [Bot] and 15 guests
