It is currently Sat Jun 13, 2026 8:11 am
 Post subject: L E D Taillights
PostPosted: Sun Jan 06, 2008 9:12 pm
Australian LUV Guru
Thinking of replaceing the tailights on my Luv with L E D type, ive been told that i may have electrical problems with the flasher can. Any one here have experience with LEDs
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sun Jan 06, 2008 9:44 pm
http://www.superbrightleds.com/carbulb-notes.htm
I've used this site for dash bulbs, it makes a huge difference in certain cars. Haven't done any exterior lighting, but I think you just need either a load resistor or an electronic flasher to make 'em work.
PostPosted: Sun Jan 06, 2008 10:59 pm
i have 39 ford teardrop tail lights on mine that are led i thought i would have to change the flasher but they work great and have had them for over a year now running stock wire and flasher
PostPosted: Mon Jan 07, 2008 7:12 am
In big rigs I think people have problems if they add too many. Then they need a special flasher unit . But running two should be fine. And the brake and parking lights should also be fine.
PostPosted: Mon Jan 07, 2008 8:04 am
PITA Old Fart
Good idea OzLuvTrucker.
My local auto parts stores all have LED replacement bulbs for exterior tail lights. I've been tempted to install them because my darn truck keeps occasionally popping tail light bulbs. According to them - they are more reliable, will take more abuse, and work better with your vehicle's electrical system.
The stock long life heavy duty bulbs I've been using aren't cheap - but the darn replacement LED bulbs are even more expensive. But if I was sure they would last longer, I'd be installing them in a damn quick hurry.
Thanks for the info Cat & nukeday...I think I'll give 'em a try.
PostPosted: Fri Jan 18, 2008 8:43 pm
WHERE DID YOU GET THOSE TAIL LIGHTS
PostPosted: Fri Jan 18, 2008 9:45 pm
Australian LUV Guru
FROM HERE http://www.narva.com.au/
