It is currently Thu Jun 11, 2026 11:08 am
 Post subject: s-10 v8 conversion
PostPosted: Tue Feb 13, 2007 3:19 pm
so I suppose putting a sbc in a s10 isnt much diferent from a luv, right? any advice would be appreciated...
PostPosted: Tue Feb 13, 2007 3:33 pm
No, a little easier. Engine compartment is a little larger.
A lot more S10 V8, than Luvs.
http://www.s10v8.com/index.php
I have been a member there for a long time too.
PostPosted: Tue Feb 13, 2007 4:41 pm
Swap Specialist Mod
yeah the s10 is a breeze compared to the luv. botl in motor mounts are available, driveline work is seldom,... stuff like that.
i would suggest that you check out http://www.v8s10.org
ive been on alot of other swap sites, and you just get alot of the newbie bashers there. v8s10.org is alot more laid back, and willing to help a guy out.
PostPosted: Sat Mar 17, 2007 7:48 pm
I used s10forum.com for a long time... its the best site I had found
There is also s-series.org, mys10.com, s-10planet.com
This was mine http://www.geocities.com/iamerron/errons-10
just a little 2.2, Cant do too much to your only daily driver.
You can also go to JTR.com (Jags that Run) and get a book for the whole DIY, very very good book. I would suggest you pick one up.
