It is currently Wed Jun 17, 2026 2:39 am
 Post subject: brake lights
PostPosted: Wed Mar 19, 2003 9:14 am
i noticed last night that my brake lights arent working. its not the bulbs cause my running lights still work. and its conected in the back. is there some sort of relay or something that could be cause this probalem. n e help would be greatly appreciated. matt
PostPosted: Wed Mar 19, 2003 10:10 am
.check your brake light switch. should be down on the pedal. has 2 wires that plug into it make suer they are conected.
i had to change the clutch pedal in mine once, dang thing broke right at the top, must have been sidesteping it to much :twisted: :lol:. anyway when i put the whole thing back together i had switched those two wires around. needless to say i didnt relize i didnt have brake lights until about 3 months later :o damn lucky i didnt get hit
PostPosted: Wed Mar 19, 2003 12:32 pm
Dont meen to make you feel stupid, but did you check the fuse? I had the same thing happen to my past luv and it was just the fuse.
PostPosted: Wed Mar 19, 2003 2:09 pm
The bulbs can also burn half out, tail lights still work but brake lights filament in the bulb is dead. Seems unlikely that both would go out at the same time though. If it is not the bulbs then it is either a fuse, the switch, or a wiring problem.
