It is currently Mon Jun 29, 2026 1:07 pm
 Post subject: BIGGER OIL PANS
PostPosted: Sat Jul 13, 2002 10:43 am
:roll: I WAS WONDERING IF THEIR IS ANY CLEARANCE PROBLEMS WHEN RUNNING THE BIGGER OIL PAN.I JUST PICKED UP A NEW MOROSO 7 QT PAN. I THOUGHT I WOULD ASK YOU GUYS ABOUT IT BEFORE BOLTING IT ON.IF THERE IS PROBLEMS PLEASE LET ME KNOW SO I CAN TAKE IT BACK & GET SOMETHING THAT WILL FIT. THANKS TERRY
 Post subject: oilpan
PostPosted: Sat Jul 13, 2002 11:40 am
I'm running a Moroso 7 Qt. with a jegs part number710-20191. It fits perfect just clearing the front crossmember by about a 3/4". I'm using advanced adapters motor mounts. Good luck Bryan
PostPosted: Sun Jul 14, 2002 1:07 pm
I`M RUNNING THE HOOKER MOUNTS. THE PAN I JUST BOUGHT IS MOROSO 20190 HOPEFULLY I WON`T HAVE ANY PROBLEMS. THANKS FOR THE INFO. TERRY
PostPosted: Sun Jul 14, 2002 7:51 pm
It's the same pan. The 91 has a built in scraper and tray. I dont know if the hooker mounts have the same engine setback as advanced adapters, I believe Ben and Derek run the hooker setup, perhaps they could help you. goodluck, Bryan
PostPosted: Sun Jul 14, 2002 10:43 pm
I didn't offer any info because I'm running the Milodon 7 quart pan (Jeg's #697-30900. The Milodon pan I'm running looks very close to the Moroso pan your talking about so I imagine you will be fine. Using the Hooker kit, I have about 1/2" of clearance between the pan sump and the crossmember. It fits so close and perfect, it's almost like it was planned for a V8. :)
Just as a FYI, I would unbolt that crossmember and remove it when your installing the engine.
PostPosted: Mon Jul 15, 2002 6:41 pm
8) thanks for the info i`m still far from dropping the motor, i wanted to get the info before bolting the pan to the short block.
