It is currently Sun Jun 28, 2026 11:46 am
 Post subject: Vin number
PostPosted: Sun Dec 31, 2006 10:45 am
I forgot to tell you that the left door was change on my luv. I was told that that is were the vin # is also.
But what I need is to know if there is a vin# on the frame. 1975
Thank You
PostPosted: Sun Dec 31, 2006 12:16 pm
There should be a placard on the door frame of the cab underneath the latch striker with the VIN# stamped on it.
 Post subject: Re: Vin number
PostPosted: Sun Dec 31, 2006 12:31 pm
Yes
On one of the rear frame crossmember supports
72 L.U.V.
427 SBC-700R4
Mustang II front suspension
LUV perf parts manufacturing
My Devotion to Karl :
PostPosted: Sun Dec 31, 2006 3:35 pm
There is another location that SOME LUV's had a VIN stamped as well. If you pop the hood, look at the passenger wiper arm and follow the arm down to below the cowl. Most early LUV's have it stamped there.
