It is currently Mon Jun 01, 2026 8:31 am
 Post subject: Hooker Mounts?
PostPosted: Wed Mar 12, 2003 7:22 pm
Are the Hooker Mounts solid or can I adapt rubber motor mounts to them.I dont really want solid motor mounts because my truck might rattle to much.If you have solid motor mounts will it rattle? :D
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Mar 12, 2003 7:43 pm
You will still need the stock rubber mounts along with the Hooker kit. The kit will set you up with mounts up to the point where you use the long bolts and the rubber mounts.
