It is currently Tue May 26, 2026 12:21 am
 Post subject: its begun
PostPosted: Fri Jul 07, 2006 1:29 am
Swap Specialist Mod
well its finnaly overcome me...
the g200 is goin tittys up on me. its smokes somethin crazy now. lost alot of power too. i guess the rings are toast. motor smoked when i bought it. im not even gonna bother with it. i got another job now, so its time for a v8.
found a 305/th350 from a running station wagon. the wagon was wrecked at 76k, so the motors good. the 305 will hold me over till i can afford bigger and better.
plan is, keep the motor stock. im gonna put a new timing set in it and slap a rebuilt qjet on it. if i can find a cheap set of block huggers ill use those, but ill more than likely use manifolds. gonna use the competition eng. motor plates for motor mounts, and fab up a tranny mount. gonna keep the stock open rear in it. just gonna be an around town rig and to the track once a month. ill look for a stock auto luv driveline or have one made with one of my th350 yokes and my stocker driveline. more than likely gonna use a camaro floor shifter, or one of those hurst unimatic jobbers.
i shouldnt be anymore than a grand into it when im done. already have some of the stuff to do it.
so as time passes ill update the post.
PostPosted: Fri Jul 07, 2006 1:34 am
you damned idaho folks just can't keep one of these things stock.... anyway.. it's too bad you weren't closer.. i could hook you up with the "good" 305 heads, driveshaft and shifter for it... well keep us post on the progress
PostPosted: Fri Jul 07, 2006 1:37 am
Swap Specialist Mod
well if you have the that auto driveline and a shifter ill prolly be keeping in touch with you. im ot really conserned with the performance aspect of the swap. the v8 alone is a triple in HP than the g200.
PostPosted: Fri Jul 07, 2006 1:38 am
i do have a LUV auto driveshaft and shifter with console so keep in touch
PostPosted: Fri Jul 07, 2006 1:42 am
Swap Specialist Mod
will do!
PostPosted: Sun Jul 09, 2006 12:55 am
Swap Specialist Mod
well i got to lookin at the from of the pup where the motorplate "would" be and theres a steering box in the way on the driver side. dang...
i was thinkin maybe a saddle mount? dont know yet. i think i could fab up a saddle mout pretty easy. just some gasseted tabs from the frame to the saddle and rubber donut mounts to absorb the vibration.
