It is currently Sun Jun 28, 2026 8:29 pm
Post new topic Reply to topic  [ 364 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19  Next
 Post subject: Re: motors in! (pic)
PostPosted: Tue Oct 07, 2008 6:35 pm
Did a little grudge racing sunday night and got the chevelle twice .
PostPosted: Tue Oct 07, 2008 6:45 pm
Congradulations!!!
PostPosted: Wed Oct 08, 2008 3:55 am
looks like you tree'd the hell out of him.
PostPosted: Thu Nov 27, 2008 6:08 am
Well they called the last race of the season and with 380 passes on the ole 355 and a new motor on the way i fugured i better take a look at ole faithfull . Pulled it out yesterday ( great oil pressure and compression still ) , took the pan off and checked the rods :smt023 , checked the mains :smt023 , retorqued everything and installed a different pan . Gave it a freah coat of paint and put it in the retirement home .
PostPosted: Thu Nov 27, 2008 8:21 am
Congratulations all the way around. 8)
PostPosted: Thu Nov 27, 2008 8:35 am
Congrates.
PostPosted: Thu Nov 27, 2008 7:30 pm
Mama's retirement home opps truck... :lol:
PostPosted: Sat Nov 29, 2008 7:49 pm
So what was the white truck
PostPosted: Sun Dec 14, 2008 7:41 pm
67 chevy C-10 .
PostPosted: Wed Jan 21, 2009 12:01 pm
Hey guys , it's been a while , my password got goofed up again and i've been off here for about 3 weeks . I have also been busy at work , which is a good thing these days . Just thought i'd give ya'll a quick rundown on my new motor .It is a vortec 4 bolt main block that i was the original disassembler around 80,000 miles . the block has had the deck squared , new ARP main bolts and stud kit installed to use the factory windage tray , it has been line bored , bores have been roughed in and are to be finish honed to blue print as rotating assembly is out for balance .The rotator is a Cola 4340 1-pc rear main crank with 3.85" stroke and radiased for H- bearing with 1800 bob weight . The rods are Lentz billets in 6" . They are an old Nascar/bursch/arca full float rod with new bushings and resized big ends in standard SBC deminsions . Flat top 2 valve relief J/E SRP "off the shelf" pistons are going on them . A Hellfire top ring and Totalseal middle ring with a low tension oil ring . All this weighs in at 1700 and some change so the balance will be material removal vs. weight added . I intend to spray this 250 at the hit after a short break in on the chassis dyno to tune the A/F ratio and curve . The truck spent Christmas at the race car shop having my flux core welds and homemade motor mounts rewelded and braced up for the new power plant . I also got into the 400 for Pinks all-out in Ennis . Im going down to the machine shop first of next week and will get some more pictures .
PostPosted: Wed Jan 21, 2009 12:39 pm
PostPosted: Wed Jan 21, 2009 8:12 pm
awesome!!
PostPosted: Sun Feb 01, 2009 9:46 pm
$680 later the rotater is balanced . The finish hone is happening soon , followed by clearencing the block . I should pick it up wendsday . Hoping to make son test passes friday followed by chassis dyno a week from tommorow ( monday ) . I NEED MY BULLET BACK :evil:
PostPosted: Sun Feb 01, 2009 10:24 pm
http://www.youtube.com/watch?v=rzU2iJ9qfXg
PostPosted: Sun Feb 01, 2009 10:27 pm
didn't work papag
I don't know how to embed something.
PostPosted: Sun Feb 01, 2009 10:28 pm
Now it works
PostPosted: Sun Feb 08, 2009 11:36 pm
well Here is a veiw of the short block assembly .
The block
Piston and rod combo
Crank installed
This is a shot of the block clearencing . Notice the rings are in the bore .
All the rods are in .
PostPosted: Sun Feb 08, 2009 11:39 pm
A few more shots of it . Can you tell im excited ?
PostPosted: Mon Feb 09, 2009 12:32 am
Looks familiar... 8)
