It is currently Fri Jun 12, 2026 10:48 pm
 Post subject: bondo
PostPosted: Thu Mar 13, 2003 11:48 pm
i have never actually bondo before. do i have to put it straight on the metal or do i need to put it over the primer? and how long do i need to let it set before i primer over it? i am primering it black bnext weekend so n e help would be appreciated
 Post subject: bondo
PostPosted: Fri Mar 14, 2003 12:06 am
k you aply it straight to the metal let sit for about 20-30 min then sand till you are satisfied make sure you do thin coats and build it up...dont just glob it on it will crack and fall out eventually spend lots of time sanding then paint make sure you put hardener in your bondo or it will take days to harden
PostPosted: Fri Mar 14, 2003 12:07 am
cool thanx
PostPosted: Fri Mar 14, 2003 12:23 am
Apply the bondo to bare metal and make sure the area is really clean and rust free, any tiny bit of oxidation will bubble through after time. I have a couple of spots on my bed the body guy didn't do a thourough job on and the paint is bubbleing underneath. Also remeber, the less you have to bondo, depth and size of area, the better it will be.
PostPosted: Fri Mar 14, 2003 3:02 pm
the 'cheese grader" bondo tool is an elbow saver. If you apply the bondo too thick, wait till it gets firm but not set (rock hard) and run the grader over it a few times. this will take down all the high spots and save a TON of sanding. I also learned that if you dont get it Perfect the first time, dont stress, another thin coat may help. Also you can have a lot of small pits from air bubbles in the bondo even when you sand it smooth. there is a product that is like "paint primer in a tube" (forget the name) it fills these in and sands really easy for a final finish.
g 8)
PostPosted: Sun Mar 16, 2003 8:31 am
Would that be spot putty?
PostPosted: Sun Mar 16, 2003 8:42 am
OG Lifer
That is spot puddy. John have you ever lived in Edmond, OK?
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Mon Mar 17, 2003 7:26 am
No , never lived in okey before , but i felt like i did when i went through 13 weeks of basic training at fort sill in the early 80s. My son lives in Lawton though. Why ya ask?
PostPosted: Mon Mar 17, 2003 9:44 am
OG Lifer
used to work with a guy named schoolcraft. Cant remember his firts name though.
