It is currently Sat Jun 13, 2026 11:34 am
 Post subject: sliding back glass
PostPosted: Mon May 01, 2006 10:39 pm
how hard is it too put one of these in? i have the flat sheet glass and im lookin into maybe replacing it with a slider, also does the slider come with all the rubber seals to install it? thanks billy
PostPosted: Tue May 02, 2006 12:36 am
Well it depends on where you bought it, as far as if it comes with the gasket, as far as putting it in. I don't know :?
PostPosted: Tue May 02, 2006 7:32 am
it is kinda tough you have to take your time on putting it in and if your carefull you can use your old rubber on your back glass i have one in my truck and one for sale
80 Luv with 88 trooper running gear 2.6 5sp 4x4
PostPosted: Thu May 04, 2006 3:30 pm
Japanese Redneck
its a snap. use a piece of string. tie it loosely all the way around the gasket. hold the window up to the hole as tighly as you can and pull the string in thru the window hole into the cab. it will go right in. it may take you an attempt or two but its easier than you think.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Thu May 04, 2006 8:11 pm
yeah thats sounds like a good idea i just threw the whole idea up in the air. thinking about getting one to increase the air flow in the cab. plus i think the look better. hey luke just wandering how much do you want foe the window?
PostPosted: Thu May 04, 2006 9:09 pm
it is a stock one for an 80 luv 4x4
20.00 + shipping
PostPosted: Thu May 04, 2006 9:12 pm
that sounds cool im not in any hurry but when you get a minute can you see how much shipping would be for zip 71111. thanks billy
PostPosted: Thu May 04, 2006 9:13 pm
ok i can do that
Users browsing this forum: Baidu [Spider] and 26 guests
