It is currently Sat Jun 13, 2026 2:31 pm
 Post subject: smog part
PostPosted: Mon Mar 20, 2006 11:34 pm
i dont have to worry about smog here in louisiana but i was wandering if you take the smog pump off how do you run your belts? wont the belt be to big if you take the pump off cause your not having to go around it anymore? also i was reading another post and a restrictor was mentioned on the exhaust, where is it located and what does it do?
PostPosted: Mon Mar 20, 2006 11:44 pm
i just run one small belt
PostPosted: Tue Mar 21, 2006 3:42 am
the smog pump should have its own belt so it shouldnt be a problem...
PostPosted: Tue Mar 21, 2006 9:20 pm
cool so all i have to do is take the pump and the belt off and whala? will the truck run diffrent if i take this off? if so what will i need to do? thanks
Users browsing this forum: Baidu [Spider] and 39 guests
