It is currently Sat Jun 13, 2026 1:05 pm
 Post subject: weber carbs
PostPosted: Thu Aug 11, 2005 11:05 pm
if you have the stock 1.8L engine what is the style weber carb do you need? i know it is the 32/36right but what is dgv and dgev stuff? plus i see alot of these on ebay, how do i know which one will fir my truck? if this was already asked i apologize i'm just having bad carb problems right now( backfiring through my exhaust) thanks for the help if any
billy
PostPosted: Fri Aug 12, 2005 1:12 am
the dgev is an electric choke and the dgv is a manual i think. Which choke to use is all up to preferance.
PostPosted: Fri Aug 12, 2005 12:02 pm
and dgav is water choke, but yes they are all the same except the choke and will fit with the proper adapter
PostPosted: Fri Aug 12, 2005 11:47 pm
so what does it matter what choke you get i have no idea about carbs more of a efi guy.
PostPosted: Sat Aug 13, 2005 1:27 am
it doesn't mater but more what you like. most people go with the auto choke , I like the manual choke
PostPosted: Sat Aug 13, 2005 11:34 am
For ease of setup and starting go with the electric choke DGEV. The manual choke works ok, but you'll have to mess with it each time you start up and adjust it down over the first ten minutes or so of running. I've had both and niether is perfect but the electric is a lot less hassle each time you fire it up. The manual you can fine tune it to run just perfectly right at any given moment, but as the motor warms up you have to keep readjusting. The electric isn't as precise, but it will run cold and turn itself off when hot. I tended to forget to pull off the choke for a while when I had a manual.
The water choke actually has a pipe in and out for water so that once the water gets up to temp the choke backs off. It would be a pain to pipe it in but it probably has a little better time of adjusting to the actual motor temps more precisely. I've never used one though. I'd bet the electric would be just about as good for the most part.
PostPosted: Sat Aug 13, 2005 11:30 pm
sweet ill keep that all in mind when i get one. There isn't any special installation for the 2 carbs are there , like running new wires or anything like that for the choke? or do they both just bolt up to where the factory one other then an adaptor plate? thanks for the advise
