It is currently Mon May 25, 2026 6:56 am
 Post subject: Speedometer cable
PostPosted: Thu Mar 02, 2017 6:19 pm
Does anyone know of a speedometer cable that will hook to the stock speedometer and a Turbo 350 ? My truck did not come with one so I don't know if a stock one will work .
 Post subject: Re: Speedometer cable
PostPosted: Wed Mar 29, 2017 6:35 pm
This forum is so boring. Hard to get help through here.
Stock speedo cable should work on your th350.l just get the cable speedo set to calibrate the actual speed showing on your cluster. May be way off if u leave the stock sppedo cable plastic bearings.
My luv project
https://youtu.be/wd5eCjrNL6U
PostPosted: Thu Apr 06, 2017 8:17 am
Thank You !
