It is currently Sat May 30, 2026 9:08 pm
 Post subject: Assembly Diagram
PostPosted: Sun Oct 23, 2016 3:08 pm
Looking for some sort of assembly diagram for a 1981 Luv. Specifically I'd like to see the front frame assembly for the motor mount placement. We have a 81 with the motor set back 10 inches in the frame, the cab needs to be replaced. The cab was customized to accept the new motor placement, but years of abuse and neglect took it's toll. So we figured we'd put the motor mounts back where they were originally.
Oh, I neglected to mention that the truck had a GM 355 in it prior to our acquiring it. By the time we're done goofing with it we hope to have a LS6 up and running.
Any ideas? Thanks.
 Post subject: Re: Assembly Diagram
PostPosted: Mon Oct 24, 2016 6:41 pm
Not sure you will find one, I haven't heard of one. My advise is to set the cab on, get hooker weld in mounts and place the engine where you want. I didn't like the placement of the kits so I made my own mounts and placed the engine lower and as far back as I could.
