It is currently Sun May 31, 2026 3:38 am
 Post subject: Weber
PostPosted: Thu May 23, 2013 4:47 am
I have a 1979 and 1975 LUV's. I have been poking around this site for awhile and recently joined up. I have seen a lot of post for changing to a weber carb from the original Hitachi. Are these available online? What are the benefits?
Also, occasionally when cut off, my 79 will "deisel" over. I have rebuild the carb, checked all my fuel lines, checked all vacuum lines, and almost put in some dynamite. Any suggestions? :evil:
'75 LUV Mikado '79 LUV 4x4
 Post subject: Re: Weber
PostPosted: Thu May 23, 2013 8:04 am
Make sure you have all the wires hooked back up to the stock carb correctly after the re-build. They have an anti-dieseling solenoid to prevent the very symptom you described. There is the electric choke, the solenoid, possibly more that need reconnected.
Yes, Weber carbs are available online, webercarbsdirect & redline are two good direct sources, places like Summit Racing sell them plus they are all over ebay from lots of independent suppliers. Just be careful it's actually a Weber, there are knock-offs out there. The K696 kit with the 32/36 DGEV electronic choke is probably the best choice.
The main difference in a Weber is the throttle response. Webers are manual secondary, stock carbs are vacuum. As you apply throttle at a set point the manual linkage opens the secondary & adds more fuel mix, no matter the engine rpm. With the vacuum secondary the engine must come to a high enough rpm to produce enough vacuum to open the secondary & add more fuel mix.
It's best to add a fuel pressure regulator, Weber recommends 3psi max fuel pressure, stock fuel pumps are rated 4-7psi.
