It is currently Fri Jun 12, 2026 11:14 pm
 Post subject: Torsion Bar
PostPosted: Sun May 23, 2010 1:11 pm
I was wondering. The 4x4 I have sits an inch lower on the passenger side. i wonder if that is because the torsion bar is gone on that side and the driver side still has it on. Guess I should take it off as well huh. This thing is sure quick with the 4:10 gears it gets to 3rd very soon. not much for highway use.
 Post subject: Re: Torsion Bar
PostPosted: Sun May 23, 2010 7:43 pm
are you missing one? or you just took it off? what is installed to keep it at its current height?
PostPosted: Mon May 24, 2010 9:40 am
Actually they cut the passenger side off to put the latemodel transfer case in and left the drivers side.
it has a homeade coil spring and shock set up on the front on each side. will have to send a pic sometime of the setup. KINDA rugged but works.
PostPosted: Mon May 24, 2010 11:13 am
i was gonna say ill be taking my bars out here eventually. you are welcome to them if that helps. but since you said stuff was cut out .. i dont really know if they would work
PostPosted: Mon May 24, 2010 4:38 pm
The late model transfer case wouldn't fit with the torsion bar in so they took it out and did the coil stuff.
By the way I am playing in a bar at Warrenton regularly. Just a small place were it is loud.
PostPosted: Mon May 24, 2010 11:24 pm
where in warrenton? i dont make it out there too often, but id make a special trip. weekends?
PostPosted: Tue May 25, 2010 9:37 am
yeah it's friday night. I also have a gig down at the Mt pleasant winery June 5th from 3-7
PostPosted: Tue May 25, 2010 1:13 pm
hmm. i close my store friday. dont know how long ya play. or if i would feel like driving to warrenton after all day at work
carry on with the topic at hand. PM me if you wish
PostPosted: Wed May 26, 2010 5:49 am
Guess I'll pull the torsionbar on the drivers side too since the other is gone . Should drop the height I would think to match the other.
The guy that did the work said he had to heat the coil spring top get the same height . Might have to get a nother set of old coils off the front of a car somewhere. need to get pics of this guys setup. Really kinda clever
PostPosted: Wed May 26, 2010 6:18 am
yeah man get some pictures. im kinda curious how this is all set up
