It is currently Sat Jun 13, 2026 1:50 am
 Post subject: Hey Polishedsteel
PostPosted: Thu Jul 31, 2003 4:13 pm
Hey polishedsteel............how 'd the driveline work out?I'm sure you've taken it around the block right?Just checking.
 Post subject: driveshaft
PostPosted: Sat Aug 02, 2003 12:58 pm
waiting on trans and heads send heads to hardheads heads here in laf these guy is good bought transbrake freshed motor 575solid cam hope to be in low10's on motor high nines on bottle feed screaming smallblock did howard get that roadster in the nines AGAIN THANKS FOR DRIVESHAFT tell howard hello take care from THE BLUE WATERS OF GULF OF MEXICO!!!!!!!!!!!!!!! PS I HOPE IT STANDS ON REAR BUMPERWHEN IT LEAVES :D
 Post subject: hey Bobby
PostPosted: Sat Aug 02, 2003 2:20 pm
sounds like some seriuos upgrades............no Howards cars didnt go nines..........we jacked with the timing car went 10.55 checked plugs car was running way bad lean,had no extra jets so he put it up for the night.The same night I was running Johns little chevy2 after 2 passes broke a wire going to the alt. fixed it at the track then went home. :drinking:
