It is currently Sat Jun 13, 2026 10:13 am
 Post subject: Relay wiring
PostPosted: Mon Jan 28, 2008 9:18 pm
Can anyone put a wiring diagram on here how to wire up my electric fan and relay and my electric water pump with a relay.
I took all my wires loose and yep lost my notes.
I have 2 number 10 red hot wires and a ground on my fan. my pump just has 2 14 guage wires with a relay;
Do I need to run a relay on my fuel pum or just the fuse as I have it now.
If you use relays do you need fuses on them.\
Old and senile here.
I have everything all wired back up but those. I have toggles in my dash for each with a constant hot fuse block
Thanks
PostPosted: Tue Jan 29, 2008 8:35 am
Usually the relays have the wiring diagram on the side of them.
There are two ways to wire a relay into the elect.system.
The power in and out is always the same but to activate it is where the diff. is .
you run one side to ground and the other to a switch. or the way i like to wire one is to run a jump wire from the power in to the switch end then wire the ground to my switch and ground the relay to activate.
I do it this way so i can have the relay close to the power sorce and or what i am powering then my longest wire is nothing more then a ground wire and less problems with power loss do to long wiring.
PostPosted: Tue Jan 29, 2008 5:13 pm
Hmmmm, so my electric water pump relay needs to be inside next to my new fuse panel.
my realy on the electric fan has the temp control on it. I have the small ground wire still hooked up to the frame. I have 2 number 10 gauge hot wires off the fan. i know one is the power because I left the inline fuse on it but want to do away with it and use the fuse in my new block.
Users browsing this forum: Google [Bot] and 22 guests
