It is currently Sat Jun 13, 2026 1:40 pm
 Post subject: Chevy Luv cabs
PostPosted: Mon Apr 23, 2007 8:01 am
My cab is pretty rusted out at the bottom of the door jams, around the front windsheild and the pass. side floorpan. Are all model cabs the same? I have a 1980 model and would want everything to fit if I get a new cab. Thanks!
LOUISIANA BOY HERE!
PostPosted: Tue Apr 24, 2007 8:33 am
There are people here that are better at answering you then me but i can tell you that the 80 has a cable clutch and 77s back had hyd. but do not fear as the 78-80 cab have the spot still in the firewall to drill out and use the hyd setup. This is what i did to my 78 but i used a willwood hyd. setup. If you look at the firewall from inside you can see the spot for the hyd. cyl. and bolt pattern that needs drill out. Hope this helps.
PostPosted: Tue Apr 24, 2007 10:02 am
I put a 78 cab on my 74 frame, no problems at all.
