It is currently Wed Apr 22, 2026 9:52 am
 Post subject: Another newbie
PostPosted: Mon Apr 09, 2018 7:23 am
I'm sporting an 81 luv machine 2wd with 37000 miles on it. I'm the second owner.she is pampered daily. Ready to get repainted
Preston
 Post subject: Re: Another newbie
PostPosted: Mon Apr 09, 2018 8:59 am
Whoah, 37,000 miles? Wow! Gas, or diesel?
PostPosted: Mon Apr 09, 2018 8:22 pm
It's gas
Preston
PostPosted: Mon Apr 09, 2018 10:16 pm
37K!!! It's just a baby. Enjoy! 8)
PostPosted: Tue Apr 10, 2018 10:32 am
I've had motor tranny and rearend redone, new suspension. Now working on heater, can't figure out why I'm not getting power, fuses are good
Preston
PostPosted: Tue Apr 10, 2018 10:56 am
The blower is fed from a relay that the manual class "charge warning relay". If that relay doesn't close, the blower won't work. The engine must be running, and the alternator must be charging.
PostPosted: Tue Apr 10, 2018 1:58 pm
You wouldn't happen to know where that's at
Preston
PostPosted: Tue Apr 10, 2018 2:14 pm
Sure, it's under the hood, somewhere around the driver's side fender. You will need a multi-tester to troubleshoot this, and you really need access to a wiring schematic. There are two or three relays there.
If you find the relay is bad, it's pretty generic and can be salvaged from quite a few more common vehicles. I can get you a list, if you end up needing it.
PostPosted: Tue Apr 10, 2018 4:43 pm
I ok thank you
Preston
