It is currently Fri May 22, 2026 12:35 pm
PostPosted: Mon Apr 02, 2018 8:01 am
Putting a SBC 350 into an '80!
Have the transmission (T350) and a rear end out of an Isuzu Trooper (with discs)
The block is at the machine shop getting a mild build.
I'm following the "Beer budget" build with some tweaks and this youtube rebuild for the engine: https://www.youtube.com/watch?v=f7mvgf6_p1g&t=461s
So, my question:
1. Some of the beer budget prices are way off - Hooker hearders are at least double the price - any "updates" to speak of that are more budget conscious? Or is that just inflation/difficulty to find etc.
2. The block is pre-vortec heads, but i pulled a couple of vortec heads of a denali at a pick 'n' pull on a half price day ($60 total). Any suggestions for a good intake manifold for vortec and a carb? I'm planning to run a Holley 600cfm double pumper (i know it's small, but it's that of a 750cfm double and that's too big).
3. Has anyone run a B&M QuickSilver Shifter? Is it tall enough? My truck was a stick, but i'm switching it (sad to lose the stick, but i can't find a transmission that doesn't break the budget or need a huge rebuild.
Thanks for your advice!
1980 Chevy Luv (SBC350 and TH350 mounted!) front suspension install, trooper rear end with 4.10 gearing, needs driveline, brakes, and getting it running!
1968 Datsun Roadster - happy as ever!
1991 Nissan 300zx Twin Turbo (daily as possible)
PostPosted: Mon Apr 02, 2018 12:38 pm
So, my question:
just an old thread id assume it all costs more by now. Check with powerbyace they probably have headers and mounts for you
i did the sane with the 4.3 block and vortec heads, edelbrock makes manifolds specifically for putting those heads on earlier blocks
PostPosted: Mon Apr 02, 2018 3:24 pm
Thanks love4theluv,
I have seen the edelbrock, but it looks like they have two extra bolt holes in the middle... Is that not true... I don't have any holes on the block.
https://www.speedwaymotors.com/Edelbroc ... 09462.html
Am I just being weird?
PostPosted: Mon Apr 02, 2018 3:51 pm
Thanks love4theluv,
Those look unrelated to mounting the manifold and dont appear to go through. Maybe theyre a mount point for some type of linkage or similar? My v6 manifold didnt have the extra mount holes so i cant help much
PostPosted: Mon Apr 02, 2018 7:31 pm
They make Vortec specific manifolds. I am running 2 now (on different vehicles). I have a quicksilver shifter in my street LUV..
PostPosted: Mon Apr 02, 2018 7:41 pm
Looks like this is what you want. Cheaper too
https://www.speedwaymotors.com/Edelbroc ... 51604.html
