It is currently Thu Jun 25, 2026 4:59 pm
 Post subject: 76 luv
PostPosted: Thu Dec 22, 2016 2:05 pm
well the im cleaning the inside of the cab and i started ripping off the dash foam but i started on the passanger side and then moved to the driver side and thats when i realized that i think the foam is holding the plastic center piece for the spedometer and other things like turn signal etc if i continue to rip it off will the center peice fall
 Post subject: mytmouz
PostPosted: Thu Dec 22, 2016 2:08 pm
That piece bolts through the foam and the metal framr...
 Post subject: Re: 76 luv
PostPosted: Thu Dec 22, 2016 2:10 pm
so it will be fine if i rip it all of ? or should i use a box cutter and carefully glide my way around the area that is left
PostPosted: Thu Dec 22, 2016 2:12 pm
I would cut around it...
PostPosted: Thu Dec 22, 2016 2:16 pm
alright well thank you guys if i have any other concerns ill come back inside and come back to the forums lol
PostPosted: Thu Dec 22, 2016 3:02 pm
was about to vacuum out the cab and to my surprise the last person to put away the extension cord tangled it all up i sat there for 10 mins untangling it and im not done yet there is still 4 big knots in it
