It is currently Mon Jun 24, 2019 7:51 pm
 Post subject: Re: 76 Luv Hot Rod
PostPosted: Sat May 28, 2016 4:33 am
Pull the gauge and make sure the wires are not shorted on the front side around the winding area .
PostPosted: Wed Jun 08, 2016 5:15 pm
Well I did that test, I show 11.8 volts across the 2 points indicated, and 128 ohms resistance across those 2 points. So it's close, probably not indicating that the voltage regulator has died on me. I still can't figure out why it was working before and then quit. Meanwhile other things I had working like the blinkers and 4 way flashers have stopped working. The electrical gremlins in this truck are driving me nuts!
When the only tool you have is a hammer, everything looks like a nail.
PostPosted: Wed Jun 15, 2016 8:18 pm
Can somebody give me advice on door hinges? My top drivers side door hinge has a ton of slop in it, does anybody sell replacements?
PostPosted: Fri Jul 01, 2016 2:07 pm
What's the thoughts on an 81 front bumper on a 76? I found an 81 bumper in pretty good shape but it looks basically straight where the original one had some indention formed into it to match the grill, etc.
PostPosted: Sun Oct 30, 2016 4:34 am
Can someone tell what this piece is called, the sheetmetal piece that goes the behind the bumper.
PostPosted: Sun Oct 30, 2016 8:03 am
Front valance. That is the early style with the thin front bumper.
PostPosted: Mon Sep 25, 2017 3:47 am
I was thinking of going this route with my wheels and tires, 6 lug 15 inch rims off a late model Colorado. But when I go to mount them to the truck, they are too wide and touch the grease fitting of the upper control arm.
PostPosted: Wed Sep 27, 2017 5:29 am
Can you put a spacer on them? As long as its only 1/2 inch it shouldnt hurt anything.
PostPosted: Thu Sep 28, 2017 4:47 am
I was looking at these to move it out 1 inch - they also come in 1.5 inch and 2 inch thicknesses which is more than I think I would need.
PostPosted: Mon Dec 25, 2017 12:39 am
I need to replace the rocker panels underneath the doors, does anyone have a suggestion for a vehicle that is common enough that panels are made, that would be close enough to match up fairly well?
