It is currently Thu Jun 25, 2026 9:24 am
 Post subject: 81 Luv LS Swap
PostPosted: Sun Jan 29, 2017 6:47 am
Bought an 81 Luv with the intent of swapping an LS motor in. We found that the 81 had some major hidden rust and wasn't serviceable. Bought a different cab and we're now in the process of building one out of two.
Here's the plan:
LM7 5.3 (LS based out of a 2000 Silverado) Short block is machined 0.030 over with flat top pistons.
LS6 (243) heads and intake
4L60e transmission
S-10 differential (373 gears) (mini spool) until we blow it out, then Ford 9".
