It is currently Tue Mar 19, 2019 2:19 am
Post new topic Reply to topic  [ 202 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 11  Next
PostPosted: Mon Aug 25, 2014 2:17 pm
PostPosted: Fri Aug 29, 2014 10:39 am
Work is slowing me down greatly on the truck. I have removed the driver side rocker, and that side has at some point hung on a stump, it looks like. I removed the inner structure as well from the donor panel and I have that in place to repair the stump damage, and the rocker ready to weld in when I get a chance. I woke up WAAYYY to early this morning and went back to the yard where i got the grille and bezels and cut the front of the yard truck off, pretty sweet deal and in excellent shape. I will transfer it after I finish the rocker...
PostPosted: Fri Aug 29, 2014 10:12 pm
How is the floor in the bed? I have wondered about putting a wood floor like the older style trucks in a Luv, even a regular bed.. since it is a driver I am not sure the weight of the floor would matter..
PostPosted: Fri Aug 29, 2014 10:26 pm
Mine is a stepside, the bottom of the bed is metal though...
PostPosted: Sun Aug 31, 2014 1:24 pm
Yes mine to. I just thought it would look cool. Especially if you show it. I did see a diamond plate one somewhere.
PostPosted: Sat Sep 06, 2014 5:31 pm
Got back on this some today. I got the driver side rocker roughed in, and a cab corner section on that side also. Then I removed the front (I hate spot welds, lol) and opened up the front of the replacement for the larger radiator and roughed it in as well. I hung the fwenders on each side and made the measurements for the new one the same as the old one and had the fenders help hold it while i welded it in...
PostPosted: Mon Sep 08, 2014 10:06 pm
Looking good...
75 Luv 350/TH350 (Project in progress)
PostPosted: Mon Sep 08, 2014 10:07 pm
Looking good...
PostPosted: Tue Sep 09, 2014 4:35 am
Looking good , alot going on in that picture .
PostPosted: Mon Sep 15, 2014 11:21 am
UPS Man cometh early... Radiator came in, gave it a quick test fit...
PostPosted: Mon Sep 15, 2014 11:25 am
It has a divorced filler neck to go around the newly installed and modified core support...
And I removed about a million unused brackets and welded up holes in the firewall, and filled in where the slave cylinder and brake booster was today before work, slowly coming along...
PostPosted: Thu Sep 18, 2014 10:24 am
Rocker panels
http://www.tabcobodyparts.com/html/table_of_contents.htm
PostPosted: Thu Sep 18, 2014 11:11 am
I had a good set on a donor truck, already installed, I definitely would have ordered some if i had known of them sooner though, PITA to get off...
PostPosted: Sat Sep 20, 2014 6:54 pm
After searching for some factory LUV bucket seats and coming up empty handed on people willing to ship, I checked the parts stash and found these...
PostPosted: Sat Sep 20, 2014 6:57 pm
Those are out of a 66 Chevelle I have. After taking the pic, I started bolting them in. Made a spacer for the inside front and outside rear tracks, and the passenger side test fit is comfy, so I will roll with them...
Got all the grinding done on the outside and the inside minus a couple of pin holes and the seat holes in the floor I won't be needing. Plan to take care of them tomorrow...
PostPosted: Sun Sep 21, 2014 7:39 am
Nice seats to have laying around. Those would cost $400 plus out here and wouldn't be as nice as yours. 8)
PostPosted: Sun Sep 21, 2014 8:49 am
Thanks. Seats were already out of the car when I got it. I put them in storage until now. I wish the rest of the car was as nice...
PostPosted: Sun Sep 21, 2014 8:03 pm
Don't look like much, but I slaved away most of the day at it. FInished the bucket seat install, then I dragged it outside and turned it around, decided to leave it outside for a while to work on it (back inside now). POS Sandblaster I got I used to work on the inner fenders, and I finished smoothing the firewall. Then I removed the glass. Then I started applying the paint stripper. I am not one to go to bare metal unless needed, but the truck already has several coats of paint...
PostPosted: Mon Sep 22, 2014 10:38 pm
Soooo shiny...
PostPosted: Tue Sep 23, 2014 6:13 am
Ugh I hate blasting, but it works better than sanding. Have you tried black diamond media? They have it at tractor supply. Sand will give you silicosis.
Users browsing this forum: No registered users and 1 guest
