It is currently Tue Jun 16, 2026 12:49 pm
Post new topic Reply to topic  [ 94 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: kaotikl luv
PostPosted: Tue Dec 15, 2009 10:45 am
alright im startin athread for my build i should have a good bit of pix up to night of the build so far..heres the start of the build a lil while after i first got it
Epic Fabrication.
KAOS
 Post subject: Re: kaotikl luv
PostPosted: Tue Dec 15, 2009 11:17 pm
The question is, Where to start? Where to start?
Going to do a build non-stop from the begining or a section here and a section there until done?
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Mon Jan 11, 2010 7:11 am
im in need of a croe support for mine close to ga or some where were it wont cost a smalll fortune to ship it...and ill put more pix up my laptop caight a virus so i can get on it
Epic Fabrication.
KAOS
PostPosted: Tue Jan 12, 2010 7:06 am
i dunno why my lap top wont post pic im put them on a jump drive and load the mfrom a nother comp so i alta have some up in a day or so...sorry for the wait everybody
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 9:55 am
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 9:57 am
finally got it to let me get some pix up theses are before i started tearing in to it
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 10:19 am
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 10:20 am
the las t one on there is where i put the 4.3 rear end under it...
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 10:22 am
8 inch monster notch
my suicidedoors parallel 4 link they build some massive 4 links
thats the back with the notch and link bars in
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 10:23 am
heres a few more of the back
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 10:24 am
heres a few of where i welded the seam up on the frame
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 10:26 am
heres where we actually started the rear bag set up
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 10:28 am
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 10:29 am
started puttin the panhard bar in
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 10:31 am
t5he rear finished up with alil paint on it
at this point i have the shox mounted
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 10:34 am
ill get teh pix of the front up tomorrow...got the frame pretty much done just gotta run some lines..gas...brake and air lines and get the motor and tranny mounts in and some rims that will tuck on the back and get the body back on and start choppin it up
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 11:42 am
looking good, the only thing i would change is that you should plate the frame with 3/16 or 1/4 plate where the front 4 link mounts are welded to the frame. the frame on these trucks is very thin and those can actualy tear off under pressure. it happend on my toyota. is your panhard bar paralell to the ground at half travel? nice welding. truck is looking good
PostPosted: Wed Jan 20, 2010 12:48 pm
Great build, keep it up! Pics brings a few questions to mind that I have had for quite a while. Why angle the rear shocks to the center as you did? How do you determine what angle is best/needed? Last, why do most solid rear axles have one shock in the front and one behind the axle? I am thinking torque has something to do with all of this. :?
Rick
Loranger, La
PostPosted: Wed Jan 20, 2010 5:18 pm
where are you suggesting i should plate the frame and as for the pan hard bar i believe it is weve cycled it through the motins and everything works fine just need to get som rims for the time being that will tuck under the bed so i can get the wheels to tucj so i can weld up the body and all
Epic Fabrication.
KAOS
PostPosted: Wed Jan 20, 2010 5:21 pm
as for your ? why i angled the rear shox is cause i really didnt have any where else to put them that wouldnt enterfer with any thing else and we pretty much got lucky on the angle its set up to lay out on 20 so we just measured for clearance fo the 20 and that pretty much put them at that angle
Epic Fabrication.
KAOS
