It is currently Sun Jun 28, 2026 5:15 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
 Post subject: my luv project....
PostPosted: Tue Jul 28, 2009 7:45 pm
 Post subject: Re: my luv project....
PostPosted: Tue Aug 25, 2009 8:06 pm
OoH a inde rear, whats it from?
much props!
PostPosted: Tue Aug 25, 2009 8:16 pm
Nice, are those your lowering blocks in the 2nd pic??? :lol: :wink:
PostPosted: Tue Aug 25, 2009 10:19 pm
MAN! every ones been step'in it up with building there luv's. I might have to as well. but looking great. keep it up!
1975 luv daily driver.
Project-soon to be revived
PostPosted: Mon Sep 07, 2009 7:34 pm
The rear end came out of a late 80's 300zx...
PostPosted: Thu Oct 08, 2009 8:22 pm
it has been awhile since i last updated, but here she is in her glory....
PostPosted: Thu Oct 08, 2009 11:58 pm
nicely done sir, any shows ur gona hit up next yr w ur luv at all?
PostPosted: Fri Oct 09, 2009 5:48 am
well i would def like to get it rolling by december, i want to take it out to turkey drag.... No other really big show until may010 showfest mississippi.
PostPosted: Fri Oct 09, 2009 10:28 am
sounds awesome.... i would like to have mine on the road this summer to, will see. I just thought id ask bc itd be nice to not be the only luv at a show lol
PostPosted: Sat Oct 10, 2009 10:29 pm
wat kind of headers are those?
SALINASRACING.COM
PostPosted: Sun Oct 11, 2009 8:24 pm
the headers i picked up at a swap meet, guy told me that he had them on an s10 that had the v-8 swap, so im assuming that they are the s10 swap headers.... the driver side loops out for the steering and it seems to work out for this truck too. Thats about all the info i have for them, that and i picked them up for 50 bucks....
PostPosted: Tue Oct 13, 2009 10:18 am
This look great but i have a question. Do you plan to brace the rear "box" assembly to the original chassis? Seems to be a lot of twisitng stress on that one square tube running side to side.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Tue Oct 13, 2009 6:33 pm
love your build between you and wickedmayhem,winerfresh...yall are making me take my build to a lil further extremes just in order to stay in the ballpark..hopefully some day ill beable to build a full frame and tackle the task of putting an irs rear end in mine..till then its it the regular frame and a boart load of crazy body mods..hope to have mine on here soon but not untill i get the biggest part of the body mods done
Epic Fabrication.
KAOS
PostPosted: Sun Oct 18, 2009 9:24 pm
the actual back half of my frame is about 2 1/2 feet inside of my original frame. the 2x3 box that i started with fit inside of the luv frame. I drilled some holes down the inside and outside of the factory frame and plug welded it in. ill try to get up some pics of that if i can find some.
This is my first build from ground up, so any pointers that anyone may have slide them to me.
PostPosted: Mon Oct 19, 2009 11:20 am
Can you send me an e-mail, effie_1953@yahoo.com, so I can send some drawings to you about my concern? I just can't get pics to post in a message. Maybe you can post them for others to chime in on. Thanks..
Rick
Loranger, La
PostPosted: Fri Dec 11, 2009 8:21 pm
PostPosted: Sun Dec 13, 2009 3:38 am
Amazing... I'd like to put IRS in a 4X4, but lack the time and funds.
Again, amazing. 8O 8)
PostPosted: Sun Dec 13, 2009 11:41 am
Camber question. How did you determine the ride height for zero camber? Once you add the weight of the truck itself, I would think the rear end would squat a bit giving you positive camber while running. I plan to do this same rear end again (this time finish it) but will have the vertical spacing of the tubes parallel to each other prevent any change in camber. Again, this is just my observation and I do tend to over think things a lot and right now is the best time for me to get as many answers to possible problems I may encounter during my build late next year.
Still one very nice looking installation you have there. Several things I never thought of doing can be seen in your pics. What size heim joints did you decide on?
Rick
Loranger, La
PostPosted: Sun Dec 13, 2009 4:12 pm
my guess is you just air up or down to get back to zero camber if it gets lower with more waight add a lil more air to get back up that is what i do with my k-5 jimmy it has triple bags in it with 40" tires and when i put more in it i go up or down it has 15"lift lol dont mean to hijack
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sun Dec 13, 2009 7:45 pm
That makes sense. It didn't come to me to do that. My plans are to use air shocks though. I do want to keep the camber as close to zero as possible through out the tires vertical travel. The roads here in Louisiana, well, suck!!!!! Seeing the use of heim joints simplifies the design and installation.
Rick
Loranger, La
