It is currently Tue May 26, 2026 7:41 am
PostPosted: Sat Apr 24, 2010 5:43 pm
hey guys
just picked up a 76 luv i seen on the side of the road, id never seen one before and had to have it
the bloke i bought it off mentioned the site so i jumped on
i love minitrucks and have done a hilux before but it wont even compare to this because they arent to common out here and they realy are something special
its fairly rough the tub was rusted right through but the cab was fairly mint, the undercarriage and cab hav had rough spray and the 1.8ltr is running on 3 cylinders but shez a project
so far iv ripped off the tub and started planning a flat bed at work as im a welder/fabricator it wil intergrate the fuel filler and battery and some harley davidson rear mudguards stretched to suit a wheel arches
pulled out the bench seat and found some bucket seats that fit nicely
plan is :)
*get the running gear mint leave 1.8ltr as im on P's tidy engine bay move battery to tray
*strip, take the cab off, shave aerial hole and side indicators and smooth back of cab, fully spray cab and undercarriage
*convert from column shift to on the floor
*re-upholster interior and bucket seats
*put the flat bed on sink it down low
*chase up some caddy lights to lay sideways in bed and some hot rod style side view mirrors
*wheels- nothing bling just big with low profile tyres
*toyota disc brakes up front
*gas strut the bonnet
and lots more
biggest thing i need advice on is lowering this thing
i dont think i want bags because it wil b a daily and cruised every friday nite and i want it to handle
im thinking reset the leafs, shortened shocks, and compressed springs and shortened struts up front
you guys know these things tho i want it to sit very low but stil driveable so it doesnt hav to b raised to get into places.
i thinking somwhere around 80-100mm just under legal :D as iv found this gets everywhere round here if you drive it right
any advice would b aprriciated
here she is
PostPosted: Sat Apr 24, 2010 9:48 pm
gday mate, fellow aussie here, sounds like you've got big plans.
how much did ya pick it up for?
if you still have that tub would ya be willing to part with it?
are you sure its a 1.8? mines a 1.6 i think most of the aussie ones are.
im also converting mine to floor shift 5 speed. im using a gemini 5 speed and shifter, i have a complete conversion kit to suit a gemini that im going to modify.
just so ya know you can sourse alot of engine and gearbox parts for sites like OZgemini and the like.
PostPosted: Sun Apr 25, 2010 12:06 am
sweet mate im from victoria wherebouts you?
picked her up for 600 bucks
mate id def part with tub but im teling you its hel rusted
im fairly sure and was told its a 1.8 but i cld easy b wrong, mate i just discovered these things dont even run springs up front haha
oh sweet as mate, i hav worked on a mate gemy and we converted that to 5 speed because beter for highway cruising so mite b the go. where did you get the conversion kit from?
and thanks for the websites il b checking them out
PostPosted: Sun Apr 25, 2010 3:12 am
yes the oz gemini site has some great info on the motor and trany... i luv it as i have a gemini and luv here in the states
PostPosted: Sun Apr 25, 2010 4:36 am
yer loving these websites giving me tons of ideas :D
PostPosted: Sun Apr 25, 2010 5:08 am
im in gippsland, victoria mate, my tub probably isnt much better, but hey if i get something useable out of it then theres a win for me
i got my conversion kit from a mate who was going to put it in his im assuming her pulled it from a wreck.
uh yeah mate no coils up front torsion bar suspension you can wind them down to get it lower.
PostPosted: Sun Apr 25, 2010 9:33 am
Welcome to the site it's nice to here and see another brother from down under has joined the group and nice truck by the way.
PostPosted: Sun Apr 25, 2010 5:29 pm
yer thanks mate im pretty stoked with it
yer wel its not that good but if your keen im not to far away haha
im considering buy a gemini with a sweet running gear as a donor and swap it all, hopefuly with a floor 5 speed
wldnt mind swapping out the single pegger dif for something better
oh sweet i had tortion bars wound down on my hiux didnt recognise it at all
thanks for that info mate
PostPosted: Sun Apr 25, 2010 5:30 pm
also im considering shortening and adapting a hilux tub is this even possible?
PostPosted: Sun Apr 25, 2010 6:53 pm
Welcome to the site. Nice looking project you've got going there.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sun Apr 25, 2010 8:01 pm
thanks mate
just been going thru the site tho and checking out some other peoples luvs its amazing
PostPosted: Sun Apr 25, 2010 9:30 pm
personally if you were going to do the swap id go for a later rodeo engine, if your planning to stick with a 4 cylinder and keeping it pretty basic.
swapping to a floor shift isnt hard just cutting a hle in the right spot for the shifter.
i havent really put much effort into looking at diffs, im looking to do a V8 conversion using a commodore driveline.
PostPosted: Tue Apr 27, 2010 2:12 am
yer wel they are a floor shift manual so yer just need the shifter and a hole cut through the floor so it should b pretty easy, hoping dont need a certificate over here to swap it over
yer im guna look into the difs wouldnt mind a lsd :D
PostPosted: Wed Apr 28, 2010 3:33 am
im pretty sure you dont need a cert.
im sure later rodeos had LSD not sure about parts compatibility though.
would you be able to chuck up some pics of the tub?
PostPosted: Wed Apr 28, 2010 5:26 am
sweet as i wasnt sure bout swaping it ova coz they came out here in column shift but floor in america
il look into it love lsd's haha
yer sure mate impretty sure its the shorter tub with he corner taiights no the round ones
PostPosted: Thu Apr 29, 2010 2:13 am
im not sure about that column shift to floor shift, one of my tradeschool teachers is an engineer so ill ask him next time i see him
being a 76 that would correct, long wheel base were later and the round lights were earlier.
PostPosted: Sun May 02, 2010 1:18 am
Il post some fotos of the tub very soon
wish i could rebuild it but im after something a bit smoother
PostPosted: Sun May 02, 2010 4:06 am
sorry the updates are going to b slow as im going to get it registered and then pull it off the road and start chopping, welding and primering haha
need a windscreen for the roady though, any ideas where in aus i can get one?
PostPosted: Mon May 03, 2010 3:58 am
Australian LUV Guru
I have two w/screens available. Im located in S.A, pm for details if interested.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Fri May 28, 2010 8:14 am
picking up a second luv on sunday :)
and built and engine crane at work for the first one and the motors out
finaly some work done
